Home > Rust Sealer
Average Rating
Write a Review or See Reviews
Email this page to a friend
$118.00
Color #1:
Color #2:
Color #3:
Color #4:
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
  • Quarts are more convenient than a gallon. Less clean-up. Less Waste.
  • Mix and match colors.
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
BEACH CAMPER   7/31/2008
EXCELLENT PRODUCT VERY USEFUL ON THE JERSEY SHORE SALT AIR ,NO MORE FRAME RUST,THE F-350 WILL LAST A FEW MORE YEARS....
Reviewed by: joseph f from NEW JERSEY.
Super Stuff !   7/31/2008
I''m doing a "frame up" restoration on a 1952 Ford F3. Brush it on and it smooths out like silk! My friends think I sprayed it on! I''ll never tell!
Reviewed by: Paul E. G. from Ash Grove, MO.
Great Paint   6/1/2008
works as good if not better than POR-15. Easy to use leaves no brush marks, looks great.
Reviewed by: Robert S. from Oakland Md.
maintenance   2/3/2008
I just put two coats on an iron entry gate and galvanized screen right next to the beach. I have been fighting rust for six years with no success. It went on very easy and coated very evenly. The convenience cans were great since I used one quart on the door so I didn''t have to put a lid back on. The jury is still out as to the effectiveness of the product. Usually in about eight months I will know how it works but so far I am very pleased with it.
Reviewed by: Danny from Holmes Beach, Florida.
Super Stuff!   5/23/2007
Fast shipping , like their product better than Por-15 , would buy again. A+++
Reviewed by: S.X.Man from Ord, NE.
Works great & cost less   11/5/2006
My new favorite. No need to pay more. Absolutely awesome product. Thanks
Reviewed by: Tom B. from Winter Haven, FL.
great deal   10/18/2006
Buying in quarts is awesome. It is much easier than painting out of a gallon can.
Reviewed by: Anita C. from Utica, OH.
worked great   10/16/2006
This stuff was so easy to work with. I used it to patch some small holes in my trunk. Very easy to work with.
Reviewed by: Fred B. from Ashley, MI.
great idea   9/20/2006
This is a great idea. I like the gallon, but it is better to get it in quarts.
Reviewed by: Fred Y. from Pickens, WV.
 Add Review 4 Quart Special :: Convenience Gallon
Review Title:
Review:
Rating:
= Required
