Home > Rust Sealer
Average Rating
Write a Review or See Reviews
Email this page to a friend
$118.00
Color #1:
Color #2:
Color #3:
Color #4:
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
  • Quarts are more convenient than a gallon. Less clean-up. Less Waste.
  • Mix and match colors.
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
Great Paint   6/1/2008
works as good if not better than POR-15. Easy to use leaves no brush marks, looks great.
Reviewed by: Robert S. from Oakland Md.
maintenance   2/3/2008
I just put two coats on an iron entry gate and galvanized screen right next to the beach. I have been fighting rust for six years with no success. It went on very easy and coated very evenly. The convenience cans were great since I used one quart on the door so I didn''t have to put a lid back on. The jury is still out as to the effectiveness of the product. Usually in about eight months I will know how it works but so far I am very pleased with it.
Reviewed by: Danny from Holmes Beach, Florida.
Super Stuff!   5/23/2007
Fast shipping , like their product better than Por-15 , would buy again. A+++
Reviewed by: S.X.Man from Ord, NE.
Write a Review
More Info from KBS Coatings
KBS 4PAK :: Convenience Quart
$45.95
$110.00
