Home > Tank Sealers
Average Rating
Write a Review or See Reviews
Email this page to a friend
Auto Fuel Tank Sealer Kit
$59.00
  • The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 25 gallons.
  • 2 Quarts of AquaKlean
  • Quart of RustBlast
  • Quart of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
  • Non-flammable
  • Environmentally safe
Save Money   7/1/2008
I have a 1957 Model 800 Ford tractor.Had a small leak in the fuel tank.$200 for a new tank or $60 to fix the old one.In my opinion,there is no choice.Good stuff !
Reviewed by: Joe Krabacher from Waynesville,Ohio.
Excellant product   6/30/2008
Used it in my 73 Bronco tank .It was very easy to work with.
Reviewed by: Mike E. from Sanford,Me.
FUEL TANK SEALER KIT   6/22/2008
I have a 19 gallon tank that has baffles, internal lines, and an unusual shape and the inside was covered with rust and crud. I used the kit and I am now driving the car on it''s fifth tank of gas (since the kit) without any problems. Thanks KBS! Also, the shipping was fast.
Reviewed by: James C. from Tulsa, OK.
Kit worked as advertised   6/2/2008
I had a problem with a car that sat for over five years...plenty of rust in the tank along with other debris. My options were another used tank for $159, a restored or new tank for $459. I chose to use KBS coatings and do not regret the choice. KBS coatings was easy to use, good instructions, coating/sealant provided good seal and tank appears new again!
Reviewed by: Glenn B from Albuquerque.
Great Product   6/2/2008
I have a problem with my VW Fuel Tank but with this product know is like new, It was rusty inside and I have problems with the carburator. Thanks to this product I can enjoy my 1959 VW Beetle I recommend this product to any one! Thanks
Reviewed by: Maggie from Sparta MI.
Auto Fuel Tank Sealer Kit   6/1/2008
This is a great product. It was easier to use than I anticipated. After using the Aquakleen and Rust Blast, the inside of the tank looked brand new. I feel confident that my rust problems are over for good. This was an inexpensive fix. BTW, the service was quicker than I expected. I used this product on a 1968 Volkswagen. Thanks.
Reviewed by: Carey K. from Brown Summit, NC.
Excellent Product, Easy to use with Great results.
Reviewed by: Jim R from Sigel,Pa..
Just the ticket!!!   6/1/2008
I have a 1960 Allis Chalmers D-17 tractor and it kept plugging the fuel line with rust this has stopped it completely looks like a new tank inside.
Reviewed by: Barry Chalfant from Casey,IA.
Great Product   5/16/2008
Instructions were simple, the process was not difficult, the tank sealer was easy to apply and coated evenly without a struggle. I am impressed with the product and will recommend it to anyone with a rusty fuel tank problem. Thanx
Reviewed by: Ryan W. from Banner Elk, NC.
Old Chris Craft Tank   4/9/2008
Very straightforward. Instructions were thorough and easy to follow. Looks good. Lets hope it holds up!
Reviewed by: PAUL C. from Queensbury, NY.
best stuff out there   4/2/2008
we've used this product on many large tanks in the yachting industry and it has worked out well and saved the owners a lot of money and down time, well i had a problem with my 86 BMW tank and thought that this product was a good choice because of the many times i've had success with it on other peoples stuff, well i wasn't let down after i was done my tank is like new and i've had no problems since thank you for a great product and great customer service they've always had the right answers
Reviewed by: mike from singer island florida.
Tank looks better than new   4/2/2008
Everything worked perfectly, the tank looked better than new.
Reviewed by: Calvin B. from Ontario Canada.
Gas Tank Sealer   4/2/2008
Worked as expected. Tank looks brand new on the inside. Thanks for a good product.
Reviewed by: Ken G. from Oxford, Mi.
Money Saver   3/6/2008
Pulled the tank on my 80 MG after letting it sit for 7 years and thought I would have to buy a new tank. Will wonders ever cease? Using your 3 step kit saved me a lot of money that I can used on other parts.
Reviewed by: NativeTexan from Houston, TX.
Director of EFCA TouchGlobal   3/4/2008
Gas tanks for the M151 military jeep are hard to find. We have a bunch with pinholes in them and I think we found the cure. The KBS sealer kit worked for us. We can use one kit to repair several tanks.
Reviewed by: Jim S. from Rockford IL.
Great for old weiding machine   3/4/2008
Could not find replacement. Kit is just what the doctor ordered. Perfect job!
Reviewed by: Paul S from Nacogdoches, TX. .
Great Kit   3/4/2008
It worked real good on the tank on an 85 MF tractor
Reviewed by: Kevin s. from Westphalia Mo..
Ground Support Manager Scottsdale Airport   2/7/2008
This stuff is great and worked like it supposed to. I recommend it highly. I used it on a 1968 Evinrude 1.5 hp out board motor. Along with the putty to fill some holes it doesn''t leak and the motor runs great now.
Reviewed by: E Miller from Scottsdale Arizona.
Wildeman   2/4/2008
I have a 40 year old RV water tank which had rusted out. I welded up most of the holes, but needed a good quality paint/sealer. Your product worked great, cleaned off all the old paint & rust, and painted, inside and out, looks like new. Thanks. JW
Reviewed by: John W. from Vallejo, Ca..
HVAC Tech   2/3/2008
Just wanted to say how well your fuel tank sealer works I love this stuff.Used it on a 1953 chevy truck fuel tank that had been sitting for 25 years,dumped out a 3 lb. coffee can of rust ,you could see daylight through this tank.I started to buy a new tank until I heard about your products.Tried it and Its great,easy to use .It saved me alot of money not having to buy a new tank.I would recomend this product to anyone wanting to repair fuel tanks,cant say enough. D. Foster Wilburton,Oklahoma
Reviewed by: Danny F. from Wilburton Oklahoma.
gas tank sealer   2/3/2008
this kit works great and the price is right.
Reviewed by: mike l from norfolk, ma.
hotrod project   2/2/2008
Used Kit On 49 Ford F-1 Fuel tank. Pleased With Results . Used remaining sealer on outside of tank. Very impressive result. thank-you!
Reviewed by: Ira L. from Forsyth, Montana.
helped seal homemade tank   2/2/2008
I took 2 tanks and made on bigger one. I had some small pin holes i could not get rid of at the seams. i used this kit and sealed it right up.
Reviewed by: Mitchell from Louisiana.
Owner   2/2/2008
Good products, did everything it was supposed to do.
Reviewed by: Charles G. from Glasgow Trailer Sales.
Tank sealer kit   2/2/2008
Great service. It arrived quickly. Easy to use, sealed a seam leak, and kept me from retro fitting my ''75 Gran Torino Wagon. Would recommend it for anyone.
Reviewed by: C D. from Columbia, SC.
Worked as described. Follow the instructions   7/7/2007
Kit worked esactly as described. Beats buying a new tank. A quality product that I have all ready recommended with some other car guys.
Reviewed by: David R from Ord, NE.
Sealing Fiberglass tank   7/6/2007
Worked well and still ends up transluscent so I could see my fuel level through the unpainted window on the tank. I think the $60 kit saved me a new $600 tank.
Reviewed by: Dirk S from Utica, OH.
GAS TANK SEALER   3/4/2007
IT WAS VERY EASLY TO USE, AND IT LOOKS LIKE A SMOOTH JOB. I WILL TRY IT AGAIN.
Reviewed by: ROBERT M. from Winter Haven, FL.
TANK SEAL   3/3/2007
Great product. It sealed my gas tank on my 1947 Chrysler
Reviewed by: John D from Pickens, WV.
GAS TANK CLEANER AND SEALER   1/5/2007
OUTSTANDING SERVICE, EXCELENT PRODUCTS
Reviewed by: RICK T. from Abelene, TX.
Just what we needed!   10/20/2006
Did just what it claimed to do.By following the directions I was able to save a the original gas tank on my farm pickup-as finding a replacement would have been impossiable-Thank You
Reviewed by: Roy U from Chicago, IL.
GREAT KIT   10/17/2006
Did a great job thanks for the product
Reviewed by: Charles R from Winter Haven, FL.
Thanks guys   10/14/2006
We`re using your kits here at the shop now. We do about 50 tank restos a year, and have used other sealers. This Gold standard stuff is all we use now! Quality, price, service that can`t be beat. Thanks much.
Reviewed by: Tanks-r-Us from Abilene, TX.
Great Kit!!   9/24/2006
Thanks!
Reviewed by: Tom H. from St. Louis, MO.
Better than a new tank   8/11/2006
I was going to buy a new tank. Then I ran across this on the internet. I ordered it and the day was saved. A lot cheaper than buying a new tank.
Reviewed by: 57chevy lover from Evansville, IN.
Simple Tank sealer kit   8/3/2006
Just like it says, this kit has all you need. My husband said I couldn`t do it. Thanks
Reviewed by: Angie F. from Raliegh, NC.
 Add Review Auto Fuel Tank Sealer Kit
Review Title:
Review:
Rating:
= Required
