Home > Tank Sealers Bookmark and Share
Average Rating
Write a Review Read Reviews on KBS Coatings Read Reviews Email Friend about KBS Coatings Email Friend
Auto Fuel Tank Sealer Kit
$59.00
  • The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 25 gallons.
  • 2 Quarts of AquaKlean
  • Quart of RustBlast
  • Quart of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
  • Non-flammable
  • Environmentally safe
KBS Instructional DVD
products worked as advertised
We used the kit on a gas tank from a '58 Dodge. The instructions were easy to follow and the products worked as advertised. Fast shipping too. Thanks much!
Reviewed by: Ralph M from Waco, TX. on 6/29/2009
Recommended it to several other gear heads.
This product worked as advertised and seems to have done an excellent job on my 1947 Studebaker gas tank. I have recommended it to several other gear heads.
Reviewed by: J Jones from Tucson AZ. on 6/29/2009
product worked great
I used the fuel tank selaer kit on an old rusty Farmall tractor gas tank. The product worked great and I would certainly use it agian.
Reviewed by: brent, w from austin, tx. on 6/3/2009
Worked Well
I used the 3-step process and am now ready to re-install the tank. It appears to have worked well. I appreciated the inclusion of the gloves.
Reviewed by: James H from Boulder, CO. on 6/1/2009
Will not stick to blaffle
I contacted KBS before ordering and asked if the sealer would stick to a plastic blaffle in a Fiero Tank. The reply was "not sure." Well, let me inform everyone, it will not. I just hope where it came off, it does not create a weak spot / expose the metal. Gave it an average rating due to my sitution. Would be better for an all metal tank.
Reviewed by: Dan H from Virginia. on 6/1/2009
See All Reviews
KBS Cycle Tank Sealer Kit
$35.00
$39.00
KBS NuMetal :: Epoxy Putty
$19.50
