Home > Restoration Kits
Average Rating
Write a Review or See Reviews
Email this page to a friend
Auto Fuel Tank Sealer Kit
$59.00
  • The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 25 gallons.
  • 2 Quarts of AquaKlean
  • Quart of RustBlast
  • Quart of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
  • Non-flammable
  • Environmentally safe
workin so far   9/4/2008
my tank was so full of rust dust that you needed a 12 pack of filters to go out for the evening. i followed the steps from KBS, (just added the six foot piece of chain /place in paint shaker for 20 minutes/rinse with hose for a hour as the first step) and have been cruisin in my ''58 rambler custom ever since. it had sat for about 20 years before i got it. find one of those tanks at a decent price!
Reviewed by: donnie a from asheville nc.
I told many of my contact and friends   9/3/2008
I am a General Contractor and ordered many differant product on line and i am never sure what you will get with your choice and I telling you this product is more than what you claimed it was. I told many of my contact and friends this product is the stuff for coating period,
Reviewed by: Rick W. from Riverside, CA .
Been 6 months and no leak   9/1/2008
Repaired and looked good when I installed it. Been 6 months and no leak and I could see light through the side of the tank. Simple instructions and easy to use. Easier if you have help with rolling a bulky tank.
Reviewed by: Brett H. from Ozark, Mo.
Very Happy   8/30/2008
I was quite IMPRESSED with the completeness of the kit. The product worked well in sealing up a gasoline tank which resembled a screen door.
Reviewed by: Larry from Winnsboro, TX.
Worked Awesome   8/29/2008
I used this product on my 1960 Edsel Fuel tank and it did a GREAT JOB of filling in the pin holes and coating the nasty rust that was in the tank, this is the only way to go when a New tank isn't available
Reviewed by: Todd from Seatac Wa.
fuel tank sealer   8/29/2008
worked great. expect to get messy though. i let mine cure for two weeks just to be sure. did several cleanings of tank first. was amazed at how much dirt and rust was removed. will use again for sure!
Reviewed by: chris c from greenville, south carolina.
Works great with no problems   8/2/2008
I ordered the tank sealer kit for my 1987 Isuzu Trooper because of a large amount of rust and debris. Getting the tank off was a task but the sealer seems to have worked perfect as I have had no problems. Very easy to use with good instructions!
Reviewed by: Joey D from Manhattan, MT.
22 year old marine alum. DIESEL TANK!   7/31/2008
I had tried to clean the tank with other products and only the cleaners in the kit even touched the grime in it. The kit works great and I highly recommend it.
Reviewed by: Joe M. from Jacksonville, Fl.
Great for Diesel   7/30/2008
I had paid good money for a shop to fix the leak the first time. I used your product to fix the first leak and the one they put in also. Great product for a DIESEL TANK!
Reviewed by: Ken K from Leavenworth, WA..
IT WORKED GOOD BUT TIME WILL TELL HOW WELL   7/30/2008
To get the max out of this product, I had to get the gas tank “absolutely” free of rust. I did use the products with the kit (Rust Buster, etc.,) to remove rust but found that only with the use of some “muratic” acid and a power-washer did I completely remove the rust. The KBS finish was applied without issue. The KBS finish is very hard and has a slick finish which is a good sign. Time ( a year or so) will really tell if the coating performs to expectations – i.e. no flaking or separating.
Reviewed by: KC Rock from Cleveland, OH.
Save Money   7/1/2008
I have a 1957 Model 800 Ford tractor.Had a small leak in the fuel tank.$200 for a new tank or $60 to fix the old one.In my opinion,there is no choice.Good stuff !
Reviewed by: Joe K from Waynesville,Ohio.
Excellant product   6/30/2008
Used it in my 73 Bronco tank .It was very easy to work with.
Reviewed by: Mike E. from Sanford,Me.
FUEL TANK SEALER KIT   6/22/2008
I have a 19 gallon tank that has baffles, internal lines, and an unusual shape and the inside was covered with rust and crud. I used the kit and I am now driving the car on it''s fifth tank of gas (since the kit) without any problems. Thanks KBS! Also, the shipping was fast.
Reviewed by: James C. from Tulsa, OK.
Great Product   6/2/2008
I have a problem with my VW Fuel Tank but with this product know is like new, It was rusty inside and I have problems with the carburator. Thanks to this product I can enjoy my 1959 VW Beetle I recommend this product to any one! Thanks
Reviewed by: Maggie from Sparta MI.
Kit worked as advertised   6/2/2008
I had a problem with a car that sat for over five years...plenty of rust in the tank along with other debris. My options were another used tank for $159, a restored or new tank for $459. I chose to use KBS coatings and do not regret the choice. KBS coatings was easy to use, good instructions, coating/sealant provided good seal and tank appears new again!
Reviewed by: Glenn B from Albuquerque.
Tank Sealer Kit   6/1/2008
Excellent Product, Easy to use with Great results.
Reviewed by: Jim R from Sigel,Pa..
Auto Fuel Tank Sealer Kit   6/1/2008
This is a great product. It was easier to use than I anticipated. After using the Aquakleen and Rust Blast, the inside of the tank looked brand new. I feel confident that my rust problems are over for good. This was an inexpensive fix. BTW, the service was quicker than I expected. I used this product on a 1968 Volkswagen. Thanks.
Reviewed by: Carey K. from Brown Summit, NC.
Just the ticket!!!   6/1/2008
I have a 1960 Allis Chalmers D-17 tractor and it kept plugging the fuel line with rust this has stopped it completely looks like a new tank inside.
Reviewed by: Barry C from Casey,IA.
Great Product   5/16/2008
Instructions were simple, the process was not difficult, the tank sealer was easy to apply and coated evenly without a struggle. I am impressed with the product and will recommend it to anyone with a rusty fuel tank problem. Thanx
Reviewed by: Ryan W. from Banner Elk, NC.
Old Chris Craft Tank   4/9/2008
Very straightforward. Instructions were thorough and easy to follow. Looks good. Lets hope it holds up!
Reviewed by: PAUL C. from Queensbury, NY.
Tank looks better than new   4/2/2008
Everything worked perfectly, the tank looked better than new.
Reviewed by: Calvin B. from Ontario Canada.
best stuff out there   4/2/2008
we've used this product on many large tanks in the yachting industry and it has worked out well and saved the owners a lot of money and down time, well i had a problem with my 86 BMW tank and thought that this product was a good choice because of the many times i've had success with it on other peoples stuff, well i wasn't let down after i was done my tank is like new and i've had no problems since thank you for a great product and great customer service they've always had the right answers
Reviewed by: mike from singer island florida.
Gas Tank Sealer   4/2/2008
Worked as expected. Tank looks brand new on the inside. Thanks for a good product.
Reviewed by: Ken G. from Oxford, Mi.
Money Saver   3/6/2008
Pulled the tank on my 80 MG after letting it sit for 7 years and thought I would have to buy a new tank. Will wonders ever cease? Using your 3 step kit saved me a lot of money that I can used on other parts.
Reviewed by: NativeTexan from Houston, TX.
Director of EFCA TouchGlobal   3/4/2008
Gas tanks for the M151 military jeep are hard to find. We have a bunch with pinholes in them and I think we found the cure. The KBS sealer kit worked for us. We can use one kit to repair several tanks.
Reviewed by: Jim S. from Rockford IL.
Great Kit   3/4/2008
It worked real good on the tank on an 85 MF tractor
Reviewed by: Kevin s. from Westphalia Mo..
Great for old weiding machine   3/4/2008
Could not find replacement. Kit is just what the doctor ordered. Perfect job!
Reviewed by: Paul S from Nacogdoches, TX. .
Ground Support Manager Scottsdale Airport   2/7/2008
This stuff is great and worked like it supposed to. I recommend it highly. I used it on a 1968 Evinrude 1.5 hp out board motor. Along with the putty to fill some holes it doesn''t leak and the motor runs great now.
Reviewed by: E Miller from Scottsdale Arizona.
Wildeman   2/4/2008
I have a 40 year old RV water tank which had rusted out. I welded up most of the holes, but needed a good quality paint/sealer. Your product worked great, cleaned off all the old paint & rust, and painted, inside and out, looks like new. Thanks. JW
Reviewed by: John W. from Vallejo, Ca..
HVAC Tech   2/3/2008
Just wanted to say how well your fuel tank sealer works I love this stuff.Used it on a 1953 chevy truck fuel tank that had been sitting for 25 years,dumped out a 3 lb. coffee can of rust ,you could see daylight through this tank.I started to buy a new tank until I heard about your products.Tried it and Its great,easy to use .It saved me alot of money not having to buy a new tank.I would recomend this product to anyone wanting to repair fuel tanks,cant say enough. D. Foster Wilburton,Oklahoma
Reviewed by: Danny F. from Wilburton Oklahoma.
gas tank sealer   2/3/2008
this kit works great and the price is right.
Reviewed by: mike l from norfolk, ma.
helped seal homemade tank   2/2/2008
I took 2 tanks and made on bigger one. I had some small pin holes i could not get rid of at the seams. i used this kit and sealed it right up.
Reviewed by: Mitchell from Louisiana.
Owner   2/2/2008
Good products, did everything it was supposed to do.
Reviewed by: Charles G. from Glasgow Trailer Sales.
Tank sealer kit   2/2/2008
Great service. It arrived quickly. Easy to use, sealed a seam leak, and kept me from retro fitting my ''75 Gran Torino Wagon. Would recommend it for anyone.
Reviewed by: C D. from Columbia, SC.
hotrod project   2/2/2008
Used Kit On 49 Ford F-1 Fuel tank. Pleased With Results . Used remaining sealer on outside of tank. Very impressive result. thank-you!
Reviewed by: Ira L. from Forsyth, Montana.
Worked as described. Follow the instructions   7/7/2007
Kit worked esactly as described. Beats buying a new tank. A quality product that I have all ready recommended with some other car guys.
Reviewed by: David R from Ord, NE.
Sealing Fiberglass tank   7/6/2007
Worked well and still ends up transluscent so I could see my fuel level through the unpainted window on the tank. I think the $60 kit saved me a new $600 tank.
Reviewed by: Dirk S from Utica, OH.
GAS TANK SEALER   3/4/2007
IT WAS VERY EASLY TO USE, AND IT LOOKS LIKE A SMOOTH JOB. I WILL TRY IT AGAIN.
Reviewed by: ROBERT M. from Winter Haven, FL.
TANK SEAL   3/3/2007
Great product. It sealed my gas tank on my 1947 Chrysler
Reviewed by: John D from Pickens, WV.
GAS TANK CLEANER AND SEALER   1/5/2007
OUTSTANDING SERVICE, EXCELENT PRODUCTS
Reviewed by: RICK T. from Abelene, TX.
Just what we needed!   10/20/2006
Did just what it claimed to do.By following the directions I was able to save a the original gas tank on my farm pickup-as finding a replacement would have been impossiable-Thank You
Reviewed by: Roy U from Chicago, IL.
GREAT KIT   10/17/2006
Did a great job thanks for the product
Reviewed by: Charles R from Winter Haven, FL.
Thanks guys   10/14/2006
We`re using your kits here at the shop now. We do about 50 tank restos a year, and have used other sealers. This Gold standard stuff is all we use now! Quality, price, service that can`t be beat. Thanks much.
Reviewed by: Tanks-r-Us from Abilene, TX.
Great Kit!!   9/24/2006
Thanks!
Reviewed by: Tom H. from St. Louis, MO.
Better than a new tank   8/11/2006
I was going to buy a new tank. Then I ran across this on the internet. I ordered it and the day was saved. A lot cheaper than buying a new tank.
Reviewed by: 57chevy lover from Evansville, IN.
Simple Tank sealer kit   8/3/2006
Just like it says, this kit has all you need. My husband said I couldn`t do it. Thanks
Reviewed by: Angie F. from Raliegh, NC.
 Add Review Auto Fuel Tank Sealer Kit
Review Title:
Review:
Rating:
= Required
