The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 25 gallons.
I have a 1957 Model 800 Ford tractor.Had a small leak in the fuel tank.$200 for a new tank or $60 to fix the old one.In my opinion,there is no choice.Good stuff !
Reviewed by:
Joe Krabacher from Waynesville,Ohio.
Excellant product
6/30/2008
Used it in my 73 Bronco tank .It was very easy to work with.
Reviewed by:
Mike E. from Sanford,Me.
FUEL TANK SEALER KIT
6/22/2008
I have a 19 gallon tank that has baffles, internal lines, and an unusual shape and the inside was covered with rust and crud. I used the kit and I am now driving the car on it''s fifth tank of gas (since the kit) without any problems. Thanks KBS!
Also, the shipping was fast.
