High Temperature Paint
Home > Topcoats Bookmark and Share
Average Rating KBS Coatings
BlackTop :: Chassis Paint
KBS BlackTop is a permanent, moisture-cured, UV stable coating primarily used for topcoating surfaces previously sealed with KBS RustSeal or any other paint/primer application. BlackTop is a high performance protective coating specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure.
8oz. - $18.75  |  Pint - $25.00  |  Quart - $42.00
Gallon - $145.00  |  5 Gallon Pail - $640.00
$0.00
Size:
Finish:
BlackTop is a permanent, moisture-cured, UV stable coating primarily used for topcoating surfaces previously sealed with RustSeal or any other paint/primer application. BlackTop is a high performance protective coating specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure. BlackTop may be used alone as a resilient coating but it will not offer the ultimate rust protection unless it is used in combination with RustSeal.
For the best stop rust & ultraviolet protection, first apply RustSeal to permanently seal the surface and then topcoat with BlackTop for an incredibly tough and professional looking finish. Like RustSeal, BlackTop dries to a rock hard yet flexible coating that can be readily applied to chassis, coil springs and light weight panels. BlackTop also has high heat resistance and can be applied to almost all automotive applications except exhaust systems. Satisfaction guaranteed!
  • Single component formula
  • Permanent UV stability
  • No chalking or fading
  • Rock hard permanent topcoat
  • Flexible coating which expands & contracts
  • High temp resistance
  • Non-porous coating
  • Superior flow and leveling
  • Apply by brush or sprayer
automotive & truck chassis • engine compartments • suspension components floor pans & trunks • wheels & rims • wrought iron railings • fire escapes
  • 8 oz. of BlackTop will cover 25 sq. ft. with two coats.
  • A Pint of BlackTop will cover 50 sq. ft. with two coats.
  • A Quart of BlackTop will cover 100 sq. ft. with two coats.
  • A Gallon of BlackTop will cover 400 sq. ft. with two coats.
  • A 5 Gallon Pail of BlackTop will cover 2000 sq. ft. with two coats.
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings Superb product
I used the Blacktop over two coats of Rust Seal and the finish turned out great. I did like the satin Rust Seal finish better than the Blacktop but the finish turned out great! I would like to have this in an spray can for touch-up and hard to reach areas. I did receive a bad can of blacktop but the replacement was at my door within 2 days. Thank you for the great products and service. I think I'll try the new Diamond finish clear coat next!
Reviewed by: William Goode from Crestview Florida. on 3/9/2010
KBS Coatings
Ratings - KBS Coatings Wow! Awesome stuff here!
Just coated my '68 C-10 frame I've spent the last few months sandblasting. Incredible stuff. Only took just over 1/2 qt. to cover the entire frame, inside and out, over 1 brushed-on coat of RustSeal. I sprayed the Blacktop and it looks awesome! What a shine! Awesome stuff!
Reviewed by: Chad M from MI. on 6/8/2009
KBS Coatings
Ratings - KBS Coatings A Seriously Good Product
I just refinished the complete interior of my 1984 Porsche 930 turbo with Satin BlackTop. After experimenting, on scraps of sheet metal, I found that spraying worked best. I learned to avoid thick coats and to allow adequate curing time between coats or tiny air bubbles develop. I applied two coats, allowing a full five days for the second coat to cure. The interior (floor, sides, and roof) looks fantastic and the BlackTop is, as AC-DC says, "hard as a rock".
Reviewed by: Benson M from Lexington, KY. on 6/1/2009
KBS Coatings
Ratings - KBS Coatings Very good product
Definitely a five star product. I would recommend it to anyone doing a frame off. I am completely satisfied with the high gloss rock hard finish.
Reviewed by: Steve H. from Kountze, Texas. on 1/2/2009
KBS Coatings
Ratings - KBS Coatings A very good product!
A very good product. Just be sure to let it set for a few days to let the paint cure. At first I Brushed it and didn't like the results, so I stripped it and sprayed it. The paint flowed on smooth and now it has a glass smooth rock hard finish. I'm very happy with the results!
Reviewed by: Joe R. from West covina, CA. on 9/2/2008
KBS Coatings
See All Reviews
Paint For Rust
Paint For Rust
KBS All-In-One Chassis Kit
$85.95
Paint For Rust
$110.00
