KBS Coatings Ordering & Info  |   Support Forum |  FAQ's & Support Tickets |  Reseller Finder |  Free Catalog
Motorcycle Resto Kits
Work Gloves
KBS Gear
KBS Work Gear
Directions Pages
The KBS 3 Step
Rust Prevention System
The KBS 3 Step
Tank Sealing System
Concrete Sealer
DiammondFinish
Clear
DF Top Coat
Fusion Self-Etching
Primer
XTC Zinc Primer
Tech Support Forum
FAQ's
1-877-548-9323
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Home > Topcoats
A tough Clear Coat that can be applied Direct To Metal or over other coatings. This water clear high gloss clear coat remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
4oz - $18.95  |  Pint - $36.95  |  Quart - $54.95
Gallon - $189.95  |  5 Gallon - $769.95
Price:
$18.95
  Only $9.95 Shipping per order.
Size:
Sheen:  High Gloss
Usually Ships Same Business Day.+More Info
Questions about this item? Ask here.Got a Question about the item? Ask Here!
(See 28 Questions)
DiamondFinish Clear Coat - Overview
Direct To Metal Clear Coat - DiamondFinish Clear
  • Formulated to Apply Directly Over Other Coatings or Direct To Metal (DTM)!
  • Permanent high solids (over 60%) and low VOC's Clear Coat.
  • Ideal for Direct To Metal (DTM) applications - No Additives Needed!
  • Apply directly to Painted Surfaces with Minimal Surface Prep.
  • Incredibly tough and hard like no other clear coat on the market.
  • Water clear high gloss clear coat remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
  • Can be applied with a brush (without leaving any brush marks), roller and conventional spray gun.
  • Unlike normal two part coatings, no hardener is needed. You can just stir and go. DiamondFinish ClearCoat will cure without heat or UV lights in temperatures from 50° to 86° Fahrenheit.
  • Can be applied directly to a cured Automotive basecoat, Standard solid color paints, and Single Part or Two Part paints. It can also be applied to Non Ferrous metals including Aluminum, Alloys, Brass, Chrome and Copper.
  • Able to withstand the harshest of chemicals including fuels, solvents, Battery acid, Brake fluid, Ethanol, Methanol, MEK, Hydrochloric Acid, Fertilizers, and Acetone.
  • Graffiti Resistant: because of its chemical resistance, grafitti just won't stick and can be removed simply with a solvent soaked rag.
  • Great for high temperature automotive applications including the use on cylinder heads, engine blocks, brake components and even inlet manifolds, without yellowing up to 250° Fahrenheit.
DiamondFinish Clear Coat - Features
  • Over 60% Solids
  • Direct To Metal Application - No Additives Needed
  • Single Part Formula
  • Tougher and Harder than 2 Part ClearCoats
  • Seals both Paints & Metals
  • Self Leveling (No brush Marks)
  • Simple Brush or Spray Application
  • High Temperature resistance suitable for Motors and Brake Callipers
  • Permanent UV Stability
  • High Chemical Resistance (including fuels)
  • Graffiti Proof
  • Recoat in 1-2 hours
  • Seals Ferrous and Non Ferrous metals
  • Breakthrough High Solids Coating Technology
DiamondFinish Clear Coat - Applications
  • Protecting steel and plastic bumpers paint work.
  • Automotive aluminium fitting, fuel tanks and parts.
  • Protecting existing paint work from physical damage.
  • Stopping chemical attack from acids and alkalis on existing paint work.
  • Protecting paint work from all fuels.
  • Sealing motorcycle fuel tanks paint work.
  • Graffiti Protection.
  • Custom Automotive Refinish.
  • Marine internal and external Refinish.
DiamondFinish Clear Coat - Coverage
Theoretical coverage at one mil (25 µm) is 400 sq.ft. per gallon/9.8 m² per liter. Recommended thickness of two mils (50 µm) would require two full coats. Three coats recommended for marine applications. Material losses during mixing and application will vary and must be taken into consideration. Expect up to 50% less coverage on bare wood, rough or sandblasted surfaces.
  • A Pint of DiamondFinish ClearCoat will cover 25 sq. ft. with two coats.
  • A Quart of DiamondFinish ClearCoat will cover 50 sq. ft. with two coats.
  • A Gallon of DiamondFinish ClearCoat will cover 200 sq. ft. with two coats.
  • A 5 Gallon Pail of DiamondFinish ClearCoat will cover 1000 sq. ft. with two coats.
Search The KBS FAQ's
DiamondFinish Clear Coat - Directions
Search The KBS Support Forum
Before...
+Larger
Before...
+Larger
Being Applied...
+Larger
After...
+Larger
After...
+Larger
After...
+Larger
DiamondFinish Clear Part #'s
Pint ... #8304
Quart ... #8404
Gallon ... #8504
5 Gal Pail ... #8604
Questions and Answers
+See All Questions  |  +Ask a Question
Q: Can this clear coat be used over laquer and enamel paint?
Asked by:  - 9/12/2013
A: Yes, DiamondFinish Clear can be applied over fully cured lacquer or enamel paints.
Was this answer helpful?   55 of 55 Customer(s) found this Answer helpful.
Answer provided by:   (9/13/2013)
Q: What is the recommendation for wet sanding and buffing times?
Asked by:  - 10/14/2013
A: DiamondFinish Clear can be cut and polished as a normal Clear Coat after 24 hours under normal conditions.
Was this answer helpful?   26 of 26 Customer(s) found this Answer helpful.
Answer provided by:   (11/11/2013)
Q: Can you use Diamondfinish Clear Coat on 1986 fiberglass Bass boat top plate? Has been wet sanded.
Asked by:  - 9/7/2013
A: Yes. Wipe the fiberglass surface down with KBS Klean. Allow to dry. Then apply the DiamondFinish Clear. It would be best to apply 2-3 coats for a marine application.
Was this answer helpful?   23 of 26 Customer(s) found this Answer helpful.
Answer provided by:   (9/8/2013)
Q: Can diamond finish clear be used over rust seal? I'm looking to use rust seal as a color base coat on some automotive components (steering rack, transmission, differential...etc) and use clear to provide the UV protective layer/topcoat
Asked by:  - 10/28/2013
A: We do not recommend putting DiamondFinish Clear over RustSeal because although DiamondFinish Clear is absolutely UV stable, DiamondFinish Clear does not block the UV rays from getting through to the RustSeal. Over an extended period of time, DiamondFinish Clear can delaminate from RustSeal when exposed to prolonged sunlight.
We always recommend a solid color UV stable top coat paint (such as BlackTop or KBS Maxx) over RustSeal if RustSeal will be exposed to sunlight.
Was this answer helpful?   18 of 22 Customer(s) found this Answer helpful.
Q: Does the clean diamond finish clear coat come in a matte or satin finish?
Asked by:  - 11/11/2013
A: At this time, the DiamondFinish Clear comes in a Gloss Finish. However, you can lightly sand the DiamondFinish Clear with steel wool after 24 hours to knock down the sheen.
Was this answer helpful?   18 of 20 Customer(s) found this Answer helpful.
Customer Reviews
Paint For Rust
BlackTop Chassis Paint
$21.95
Paint For Rust
DiamondFinish Top Coat
$34.95
Paint For Rust
All-In-One Chassis Kit
$89.95
Recently Viewed Items
Subtotal $0
Sign Up Today!
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
We Want
Part Numbers
KBS Coatings - Barbados
Barbados
KBS Coatings - Denmark
Denmark
KBS Coatings - Germany
Germany
KBS Coatings - Russia
Russia
UK
