Home > Epoxy Putty
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS NuMetal :: Epoxy Putty
KBS NuMetal Epoxy Putty is a easy-to-use, two part putty you simply mix and mold like clay – no complicated weighing or measuring required. Available in one pound box in BLACK, TAN, & WHITE!
$19.50
Color:
NuMetal Epoxy Putty is an easy-to-use, two-part putty that mixes like clay but hardens like steel! NuMetal bonds, seals, fills, insulates, anchors, caulks and waterproofs. It cures without shrinking or sagging and can be drilled, tapped, sanded, primed and painted. NuMetal will not only stick to damp surfaces, but it will cure underwater!
Our Black NuMetal is ideal for automotive applications…if the surface coating sustains damage, the black epoxy putty beneath remains unseen! Use White NuMetal for marine applications and boat repairs. Satisfaction guaranteed!
  • Bonds to almost anything
  • Cures underwater
  • Won’t shrink or sag
  • Can be applied to vertical surfaces
  • Sand, drill or carve
  • Paint, stain or gel coat
  • Withstands temps up to 300°F (150°C)
  • Easy 1:1 mix ratio
  • Cut only what you need
  • Soap & water clean up
all metals • wood • ceramic • porcelain PVC • ABS Pipe • brick • stone • leaky gas tanks • broken fuel lines • steering wheels • plastic parts/knobs • manifolds cracked fiberglass • marine repairs • pool repairs • insulate • repair holes in decks or tiles • use like modeling clay • carvings • concrete • plaster • tile • grout • tool handles
What a Great Product   6/16/2008
Even as a novice auto body repair person this was a piece of cake. It worked exactly as described. The previous bondo attempt on a rusted area on my car was no match for the repair that nu-metal gave me. I highly recommend it.
Reviewed by: Theresa from Arizona.
Worked better than expected   5/2/2008
The putty was easy to use it was also easy to mix,it had all the properties I needed and I found it easy to apply to other uses,I also found it is easy to sand and can be drilled and tapped if need be .Clean up was a snap and it seems to be a cure for alot of underwater applications ,as a working diver and mechanic I highly recommend this product!!
Reviewed by: Danny T. from old bridge N.J..
Ground Support Manager Scottsdale Airport   2/7/2008
This is fantastic stuff, the best I have used.
Reviewed by: E Miller from Scottsdale Arizona.
Write a Review
More Info from KBS Coatings
$110.00
KBS BackBone Reinforcing Mesh
$7.00
