KBS Coatings manufactures the most respected and trusted gas tank sealer in the industry today! Not only do we think of it as the NEW gold standard but we named it so! Gold Standard Tank Sealer is a superior, single component, ready-to-use sealer formulated for coating the inside of metal, aluminum & fiberglass tanks.
Widely recommended & easy-to-use, this single application coating cures into a tough fuel impervious seal. The entire tank including pinholes & weld seams are permanently sealed to prevent the return of rust & corrosion and clogged carburetors. Yet amazingly, this rock hard interior remains flexible to withstand vibration and the repeated expansion & contraction of the tank! Other sealers are little more than paint or adhesive-type coatings which have poor sealing abilities especially when exposed to today’s fuels. Wisely choose Gold Standard for an incredible long lasting seal! Satisfaction guaranteed!
Click HERE to determine How Much Tank Sealer to Order.
- 8 oz. of Gold Standard Tank Sealer will seal up to a 5 Gallon Tank.
- A Pint of Gold Standard Tank Sealer will seal up to a 12 Gallon Tank.
- A Quart of Gold Standard Tank Sealer will seal up to a 25 Gallon Tank.
- A Gallon of Gold Standard Tank Sealer will seal up to a 100 Gallon Tank.
- GOLD STANDARD TANK SEALER is non-flammable and is environmentally safe.
- Click HERE to see how Howie used Gold Standard Tank Sealer to seal a gas tank.
steel, aluminum & fiberglass fuel tanks • oil tanks • diesel tanks • utility tanks • non-potable water tanks
