Average Rating |
Back to Main |
9/1/2008 |
| We used this product to seal a very small fuel leak in a fiberglass tank on our boat ! It worked Great!!! And we are back offshore again!! Thank You !! 5 stars P S we need some distributors here in so cal |
| Reviewed by: |
Rich D from Huntington Beach CA. |
7/31/2008 |
| nice stuff, easy to work with, seem to be holding, time will tell. |
| Reviewed by: |
james h from new york. |
7/31/2008 |
| It worked great for my boat gas tank, i''m back fishing! |
| Reviewed by: |
bill from baja mexico. |
7/30/2008 |
| I found your tank sealer to do the job it was intended to do. I sealed an antique IHC 3 hp M gas tank and it worked perfectly. I''ll use it again, because it did better than the others I have use and had a better or comparable price.
"DELCO DON" |
| Reviewed by: |
Don W from Sparta IL. |
6/30/2008 |
| I won't know for a long time when I finish restoration, but it looks like a good tank sealer. |
| Reviewed by: |
James S. from Franklin, TN. |
5/31/2008 |
| SERVICE WAS PERFECT, PRODUCT EASY TO USE, WORKED PERFECTLY, OLD NORTON, AND HARLEY BACK IN SERVICE CUSTOMERS VERY HAPPY... |
| Reviewed by: |
PHIL G. from LONG BRANCH NJ. |
5/30/2008 |
| Great stuff for sealing tanks. Easy to use and does a great job. |
| Reviewed by: |
Richard M from Woodland, CA. |
4/2/2008 |
| we are using this on old tractor tanks workes really well |
| Reviewed by: |
dale d. from keithsburg ill. |
2/3/2008 |
| worked great. be sure to follow all instructions and wait for the product to harden. I gave mine an extra day just to be on the safe side. |
| Reviewed by: |
james e. p. from central west virginia. |
2/2/2008 |
| Worked super |
| Reviewed by: |
w villiers from Illinois. |
2/2/2008 |
| I collect and restore Gone With The Wind lamps and this is the best sealer that I have found in over 20 years!! This stuff works great! will buy more in the future |
| Reviewed by: |
Jim M. from Tucson Arizona. |
2/2/2008 |
| Great stuff. Works as stated. |
| Reviewed by: |
PJ from Texas. |
2/1/2008 |
| Product worked as advertised. I repaired a 1965 Oliver gas tank that was totally rusted. Repair was very easy and tractor runs great with no rust blocking the fuel line. |
| Reviewed by: |
Jesse R. from Vicksburg, MS. |
11/1/2007 |
| this is the best product i have ever used |
| Reviewed by: |
doug k from Ord, NE. |
10/9/2007 |
| Product was very easy to use and worked as described. |
| Reviewed by: |
Robert W from Utica, OH. |
9/2/2007 |
| I was very pleased with the results of the Gold Standard sealer. I am unable to say how well the AquaKlean and RustBlast worked inside my `85 Fiero tank, but from what I could see of the sealer, it worked well -- made the inside of the tank look brand new. |
| Reviewed by: |
Jerry A. P. from Winter Haven, FL. |
8/2/2007 |
| I got my order the next day. Gold Standard did exactly as promised. The tank interior was completely coated and sealed. I also painted the gas cap with a small brush and renewed it.
I will use this again- on my 1966 Rambler Classic Convertible!! |
| Reviewed by: |
Lex L from Pickens, WV. |
8/1/2007 |
| I used it in a new custom made tank, works very well. |
| Reviewed by: |
Dan A. from Graham, NC. |
7/5/2007 |
| I repaired my `81 goldwing tank with this, i had to patch a pretty bad hole first, then disolve the rust which was plentiful, then simply pour the sealer in the tank, you have to stay with it, no biggee, and roll it around so it covers everything, this stuff dries super hard.no more rust and trash in my fuel filter, glad i bought it |
| Reviewed by: |
Barry C from Abelene, TX. |
5/21/2007 |
| this product is easy to use and gives great results. |
| Reviewed by: |
Daniel B. from Chicago, IL. |
3/3/2007 |
| It worked Great. It saved me from buying a new tank. |
| Reviewed by: |
John D from Ord, NE. |
3/1/2007 |
| seals great, good product, easy to use |
| Reviewed by: |
Jeff P. from Fort Dodge, IA. |
9/24/2006 |
| fallow instructions to the t an its fairly easy,first timer to this process and it came out perfect. |
| Reviewed by: |
demar e from Hammond, IN. |
9/19/2006 |
| I had a new Spitfire tank that I wanted sealed. It was not leaking, but I just wanted something to prevent rust from forming. This Sealer work just as advertised. My friends on a forum turned me on to it and I am so glad that they did. |
| Reviewed by: |
Brad H. from Brownwood, TX. |
9/19/2006 |
| I used this is my gas tank and it worked great. It was pretty simple and that is good because I am not a pro. |
| Reviewed by: |
Steve B. from Provo, UT. |
9/19/2006 |
| I had a custom tank that was leaking. There was no way that I could get a new one. I used this stuff and it sealed up that pinhole leak that I had. |
| Reviewed by: |
Carl F. from Ashley, MI. |
6/15/2006 |
| This stuff is amazing. I followed the 3 Part System, and it sealed my tank up beautifully. Very easy and my tank does not leak anymore. |
| Reviewed by: |
Vette L. from South Barrington, IL. |
