Home > Tank Sealers
Average Rating
Write a Review or See Reviews
Email this page to a friend
Gold Standard Fuel Tank Sealer will stop rust and form a tough, fuel impervious coating while sealing small pinholes and weld seams. Your fuel will never touch the inside walls of your tank again.
8oz. - $13.00
Pint - $20.00
Quart - $32.50
Gallon - $95.00
5 Gallon Pail - $420.00
$0.00
Size:
KBS Coatings manufactures the most respected and trusted gas tank sealer in the industry today! Not only do we think of it as the NEW gold standard but we named it so! Gold Standard is a superior, single component, ready-to-use sealer formulated for coating the inside of metal, aluminum & fiberglass tanks.
Widely recommended & easy-to-use, this single application coating cures into a tough fuel impervious seal. The entire tank including pinholes & weld seams are permanently sealed to prevent the return of rust & corrosion and clogged carburetors. Yet amazingly, this rock hard interior remains flexible to withstand vibration and the repeated expansion & contraction of the tank! Other sealers are little more than paint or adhesive-type coatings which have poor sealing abilities especially when exposed to today’s fuels. Wisely choose Gold Standard for an incredible long lasting seal! Satisfaction guaranteed!
  • 8 oz. of Gold Standard Tank Sealer will seal up to a 5 Gallon Tank.
  • A Pint of Gold Standard Tank Sealer will seal up to a 12 Gallon Tank.
  • A Quart of Gold Standard Tank Sealer will seal up to a 25 Gallon Tank.
  • A Gallon of Gold Standard Tank Sealer will seal up to a 100 Gallon Tank.
  • GOLD STANDARD TANK SEALER is non-flammable and is environmentally safe.
  • Non-flammable
  • Environmentally safe
Good I think   6/30/2008
I won't know for a long time when I finish restoration, but it looks like a good tank sealer.
Reviewed by: James Sewell from Franklin, TN.
MOTORCYCLE TANKS   5/31/2008
SERVICE WAS PERFECT, PRODUCT EASY TO USE, WORKED PERFECTLY, OLD NORTON, AND HARLEY BACK IN SERVICE CUSTOMERS VERY HAPPY...
Reviewed by: PHIL GREIG from LONG BRANCH NJ.
Awesome product   5/30/2008
Great stuff for sealing tanks. Easy to use and does a great job.
Reviewed by: Richard M from Woodland, CA.
Write a Review
KBS Cycle Tank Sealer Kit
$35.00
More Info from KBS Coatings
$39.00
Auto Fuel Tank Sealer Kit
$59.00
