Howie How To - Painting Posts
Well summer was on the way and I had this spring project in mind for sometime. KBS Coating - Flat HeadI wanted to get some shade cloth up for the back of the house ... not the biggest project but enough to keep me busy for a while, which was fine by me! Anyway it all went well and the 4”x 4” posts went in and it was all looking good. As my neighbor was over for drinks, we were talking and the topic comes around to how are you going to paint those welds and the galvanised posts. See, his galvanised painting all came off 18 months after putting it on,then all the welds went rusty! He was not real happy about that. So, I figured ... here’s a good one for a Howie's How To.
KBS Coating - Pole PaintingFor the average do it yourselfer, galvanised surfaces and welds can be quite problematic. It is difficult to to find a product that both seals the welds and primes the galvanised. It is not easy and if you live near the coast you must get it right because even galvanised only lasts a few years unpainted before spot failure can occur.
So let’s get started and it’s here were most people go wrong at the very first step, firstly the weld is covered in carbon and other nasties you must clean it.
The other big mistake people make is thinking thatthe galvanized posts are clean. They are not! At many places where the steel is warehoused they put oil on the galvanized surface to stop it oxidizing and keep it looking new.No paint or etch is going to work unless you clean all of this off. Some people use solvent cleaners, but the surface is still not clean enough for an etch or for painting.
KBS Coating - Pole PaintingAll I did was mix up some AquaKlean ... about 3 parts water and 1 part AquaKlean in a spray bottle and sprayed away. Many times I use really warm water, but water straight from the hose worked well for this project. I use AquaKlean for all kinds of projects around the house ... I recently found out that it works really well for cleaning out my shower and tub.
KBS Coating - Pole PaintingI gave the welds a good scruband just wiped the rest down with a rag dipped in my AquaKlean solution. I then gave the whole thing a good spray with the hose. The whole cleaning process took no more than 5 minutes. You can see the weld is much cleaner but it still has weld scale on it. We do not want to paint over this or you will get the same result as the neighbour.
Now spray on a little RustBlast and keep it wet with the RustBlast for about 5 minutes. KBS Coating - Pole PaintingLook ... no more scale! The RustBlast is also ideal for etching the galvanized surface and it does this very quickly, you only need to leave the RustBlast on for 2-3 mins (you can see it working as the galvanizing changes color slightly). Again, put the hose into service with a quick rinse down.
All I had to do now was let it dry(I like this part because that means lunch time!) KBS Coating - Pole PaintingThen I mixed up a little RustSeal grey I had and spot primed the welds only, then followed with a coating of RustSeal over the whole thing. This gives me two coats on the welds which is a must and one coat on the plain galvanizing which is fine then a topcoat. I just used a water based house paint to match the house. An oil based topcoat would have been better (but I couldn’t get a color match in a oil based product) but because I have the RustSeal underneath it will be fine.
Here is a Howie thought ... if you are using water based latex paints in metal or corrosion protection it is a good idea to make sure you use high quantity primer system underneath as water based latex type paints have little if any ability in corrosion protection.
Just ask my neighbor!
AquaKlean - Cleaner and Degreaser
RustSeal - Stop Rust Paint
