| Make sure to only use KBS #1 Thinner for the thinning of RustSeal and our other Rust Preventive Paints. |
8oz. - $6.00
Quart - $10.50
Gallon - $33.00
5 Gallon Pail - $93.00
| Only $8.00 Shipping per order. |
| Description |
Make sure to only use KBS #1 Thinner for the thinning of RustSeal and our other Rust Preventive Paints. Regular solvents may contain moisture that can adversely affect the performance of our coatings.
Also, keep some KBS #1 Thinner on hand for your immediate clean up needs.
Customer Reviews - Others Say It Best |
Average Rating |
Back to Main |
7/5/2007 |
| Haven`t used yet but very satisfied with Rust Blast, it works great!!! I can pretty well bet that it`s some of the best, just judging from the other product |
| Reviewed by: |
Adrian Shepard from Stockton, CA. |
12/6/2006 |
| Works well for clean up and all other necessary applications, like thinning. If you have anywhere over 1 gallon of KBS Rust Seal and/or POR-15, you`ll definitely be needing this to clean up spray guns, brushes, hands or any other things that you don`t want forever coated in the paints :P |
| Reviewed by: |
Gary M from Houston, TX. |
9/19/2006 |
| This stuff worked great for cleaning up my gun after spraying RustSeal. I did not thin the RustSeal and had great results. |
| Reviewed by: |
Harry T. from Sarasota, FL. |
8/24/2006 |
| This stuff work great to clean my brushes. I let my brushes soak in this stuff in between coats. |
| Reviewed by: |
Elmer from Eubank, KY. |
