High Temperature Paint
Home > Thinners Bookmark and Share
Average Rating KBS Coatings
Make sure to only use KBS #1 Thinner for the thinning of RustSeal and our other Rust Preventive Paints.
8oz. - $6.00
Quart - $10.50
Gallon - $33.00
5 Gallon Pail - $93.00
$0.00
Size:
Make sure to only use KBS #1 Thinner for the thinning of RustSeal and our other Rust Preventive Paints. Regular solvents may contain moisture that can adversely affect the performance of our coatings.
Also, keep some KBS #1 Thinner on hand for your immediate clean up needs.
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings thinner
The thinner works great, but it does not store well. It needs to be put in a container that will not corrode.
KBS Coatings Reply: The #1 Thinner is sold in a standard Tin Can. If kept indoors and away from moisture, it will not corrode.
Reviewed by: michael r from usa. on 7/28/2009
KBS Coatings
Ratings - KBS Coatings Thinner -Works
Used for all clean up. Works as advertised. A must have with any KBS order....
Reviewed by: T S from VA. on 3/4/2009
KBS Coatings
Ratings - KBS Coatings #1 Thinner
What can you say, it''s thinner? Got it mostly for thinning the Topcoat and Rustseal for spray gun use. Acetone works just as well for clean up and is a dab cheaper.
Reviewed by: Bill O from Knoxville, Tennessee. on 7/5/2008
KBS Coatings
Haven`t used yet but very satisfied with Rust Blast, it works great!!! I can pretty well bet that it`s some of the best, just judging from the other product
Reviewed by: Adrian S. from Stockton, CA. on 7/5/2007
KBS Coatings
Ratings - KBS Coatings No doubt, it does work
Works well for clean up and all other necessary applications, like thinning. If you have anywhere over 1 gallon of KBS Rust Seal and/or POR-15, you`ll definitely be needing this to clean up spray guns, brushes, hands or any other things that you don`t want forever coated in the paints :P
Reviewed by: Gary M from Houston, TX. on 12/6/2006
KBS Coatings
See All Reviews
Paint For Rust
$109.95
Paint For Rust
Paint For Rust
BlackTop :: Chassis Paint
