Home > Restoration Kits
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS 4PAK :: Convenience Quart
$45.95
Color #1:
Color #2:
Color #3:
Color #4:
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
  • 8oz. cans are more convenient than a gallon. Less clean-up. Less Waste.
  • Mix and match colors.
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Repels fuels, oils, most acids and alkalis, and graffiti
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • 8 oz. of RustSeal will cover 12.5 sq. ft. with two coats.
  • A Pint of RustSeal will cover 25 sq. ft. with two coats.
  • A Quart of RustSeal will cover 50 sq. ft. with two coats.
  • A Gallon of RustSeal will cover 200 sq. ft. with two coats.
  • A 5 Gallon Pail of RustSeal will cover 1000 sq. ft. with two coats.
Amazing   3/4/2008
easy to use, even coat, looks great.... Thanks a lot!
Reviewed by: Jimmy S from Cape Cod.
Unbelievable colors!!   1/28/2007
got the 4 pak in the colored rustseal and I`m blown away! Beautiful colors that dry rock hard. Where have you guys been hiding this stuff? Thanks a ton.
Reviewed by: Pat D from Abelene, TX.
4Pak   9/19/2006
Good stuff, the satin is a really nice and even finish. deep black color. the silver is a little glossy for me but looks sweet! Thanks
Reviewed by: j.j. from Chicago, IL.
Write a Review
More Info from KBS Coatings
KBS Frame Coater Kit
$55.00
$118.00
