- AquaKlean - An Industrial Strength Cleaner & Degreaser.
- RustBlast - A Rust Remover & Zinc Phosphate Metal Prep.
- RustSeal - A Non Porous Waterproof, Rust Preventive Sealer. Available in your choice of 8 colors.
- BlackTop - A Superior Topcoat With Unbeatable UV Protection & Flexibility. Available in Gloss Black or OEM Satin Black.
- #1 Thinner – Use to Thin Spray Applications and for Clean Up.
- Brushes, Gloves, Stir Stick & Instructions - The Intangibles Needed For Every Project.
- Will cover 50 sq. ft. - 2 Coats of RustSeal, 1 Coat of BlackTop.
- Quart - AquaKlean
- Quart - RustBlast
- Quart - RustSeal (any color)
- Pint - BlackTop (either color)
- Black Lightning Nitrile Gloves
- Two Brushes
- Stir Stick
- Complete and Detailed Instructions
