High Temperature Paint
Home > Topcoats Bookmark and Share
Average Rating KBS Coatings
KBS All-In-One Chassis Kit
$85.95
RustSeal Color:
BlackTop Color:
*Kit includes Black Lightning Gloves, Brushes and Stir Sticks.
Gloss
Black
Satin
Black
Off-White
Clear
Grey
Silver
Oxide
Red
Guardian
Green
Galvanized
Steel
*Click HERE for the unique characteristics of Galvanized Steel.
RustSeal - Stop Rust - Like POR-15
  • AquaKlean - An Industrial Strength Cleaner & Degreaser.
  • RustBlast - A Rust Remover & Zinc Phosphate Metal Prep.
  • RustSeal - A Non Porous Waterproof, Rust Preventive Sealer. Available in your choice of 8 colors.
  • BlackTop - A Superior Topcoat With Unbeatable UV Protection & Flexibility. Available in Gloss Black or OEM Satin Black.
  • #1 Thinner – Use to Thin Spray Applications and for Clean Up.
  • Brushes, Gloves, Stir Stick & Instructions - The Intangibles Needed For Every Project.
  • Will cover 50 sq. ft. - 2 Coats of RustSeal, 1 Coat of BlackTop.
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Quart - AquaKlean
  • Quart - RustBlast
  • Pint - BlackTop (either color)
  • Black Lightning Nitrile Gloves
  • Two Brushes
  • Stir Stick
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings looked like someone sprayed the chassis rather than brushed it
I applied it in my driveway. The 1st coat went on nicely at 65-70 degrees, but it’s VERY messy. Tape off, tape off, tape off again. After setting, was glossy black with few imperfections. It looked like someone sprayed the chassis rather than brushed it on. Follow the temp reqs. I applied the 2nd coat in 45 deg. weather and it was hardly manageable. The product was too thick/dried fast. This was my fault b/c of time constraints. Overall great product. Best applied to individual pieces.
Reviewed by: Oliver W. from College Station, TX. on 3/2/2009
KBS Coatings
Ratings - KBS Coatings Looks like it did the day I painted it
Its been a little over 3 months since I painted my frame and chassis. It has been out side most of that time getting rained and snowed on. It still looks like it did the day I painted it. I just got my garage built and with the great products from KBS, I will soon have my car built. I'm looking forward to using the trunk and floorpan kit next.
Reviewed by: Bobb from Watson Il.. on 2/10/2009
KBS Coatings
Ratings - KBS Coatings great product thanks
Reviewed by: J Buckles from Linden In. on 12/30/2008
KBS Coatings
nice finish, easy application, very satisfied... 5 stars *****
Reviewed by: fernado g from eagle pass, tx.. on 7/30/2008
KBS Coatings
Ratings - KBS Coatings Great kit
Complete and effective. Delivery prompt. Very satisfied
Reviewed by: Jim H from California. on 5/2/2008
KBS Coatings
See All Reviews
Paint For Rust
Paint For Rust
Paint For Rust
BlackTop :: Chassis Paint
