Home > Restoration Kits
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS All-In-One Chassis Kit
$85.95
RustSeal Color:
BlackTop Color:
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
  • AquaKlean - An Industrial Strength Cleaner & Degreaser.
  • RustBlast - A Rust Remover & Zinc Phosphate Metal Prep.
  • RustSeal - A Non Porous Waterproof, Rust Preventive Sealer. Available in your choice of 8 colors.
  • BlackTop - A Superior Topcoat With Unbeatable UV Protection & Flexibility. Available in Gloss Black or OEM Satin Black.
  • #1 Thinner – Use to Thin Spray Applications and for Clean Up.
  • Brushes, Gloves, Stir Stick & Instructions - The Intangibles Needed For Every Project.
  • Will cover 50 sq. ft. - 2 Coats of RustSeal, 1 Coat of BlackTop.
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Quart - AquaKlean
  • Quart - RustBlast
  • Pint - BlackTop (either color)
  • Black Lightning Nitrile Gloves
  • Two Brushes
  • Stir Stick
Great kit   5/2/2008
Complete and effective. Delivery prompt. Very satisfied
Reviewed by: Jim H from California.
perfect kit   12/10/2007
this was the perfect kit. had everything i needed and both coatings flowed out like glass. i could not believe it because i brushed it on.
Reviewed by: Adam S from Seattle, WA.
 Add Review KBS All-In-One Chassis Kit
Review Title:
Review:
Rating:
= Required
