High Temperature Paint
Home > Prep Products Bookmark and Share
Average Rating KBS Coatings
KBS AquaKlean
KBS AquaKlean
AquaKlean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents & hazardous chemicals for preparing your paint job with a clean surface. This powerful cleaner will deeply penetrate and remove stubborn soil from most surfaces without leaving harmful residues or emitting noxious fumes.
8oz. - $6.00  |  Quart - $9.95
Gallon (w/ spray bottle) - $19.00  |  5 Gallon - $76.00
$0.00
Size:
AquaKlean - Water Based Cleaner and Degreaser
Perfect for the home, garage, or plant to effectively remove dirt, grime, oils, lubricants, grease, waxes, scum, algae, road film and other contaminants. AquaKlean may be used in pressure washing equipment to produce the rapid penetration of many layers of accumulated build up. Cleaning projects have never been easier! Satisfaction guaranteed!
AquaKlean Applications Include:
  • steel
  • iron
  • fiberglass
  • concrete
  • plastics
  • nylon
  • brass
  • automotive & diesel engines
  • truck trailers
  • compressors
  • holding tanks
  • engine room pumping equipment
  • tools
  • ovens
  • bbq grills
  • painted finishes
  • galvanized
  • aluminum
  • stainless steel
  • canvas
  • vinyl
  • air conditioner systems
  • grease traps
  • floor pans
  • fuel tanks
  • porcelain sinks
  • tubs
  • asphalt
  • lawn mowers
FEATURES:
  • Guaranteed pre-paint performance
  • Economical concentrated formula
  • Low foaming, leaves no residues
  • Oxygen-Block enhanced for short term corrosion protection
  • Non-flammable, no petroleum additives
  • Non-corrosive, non-toxic
  • Environmentally safe, phosphate-free
  • Safe on non-ferrous metals like aluminum
  • Powerful low temp cleaning action
  • Click HERE to see how Howie cleaned a Ford Flat Head before he etched it and sealed it.
  • Click HERE to see how Howie cleaned some posts and the welds before he etched and painted them.
  • 1 Gallon of AquaKlean for each Gallon of KBS RustSeal
  • Each Gallon comes with a Bottle and Sprayer
  • 1 Quart of AquaKlean for each Quart of KBS RustSeal
  • 8oz. of AquaKlean for each 8oz. of KBS RustSeal
KBS AquaKlean
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings This stuff is great
I used this on my boat fuel tank and it was amazing. It had several compartments in it and this product made coating all the sides of the fuel tank very easy. I wasgetting aluminum dust in my fuel so i used the cleaner and I was amazed at how much I got out of the tank. I coated the inside and outside of the tank and was very pleased with the results. I would recommend these products to anyone.'
Reviewed by: John H from Hinesville, GA.. on 9/28/2009
KBS Coatings
Ratings - KBS Coatings kit did a very good job
I ordered the gas tank repair kit for my honda generator it holds 5 gal.so i got the motorcycle kit. My tank had rust and gunk in it. It took time but the kit did a very good job. I am looking at the new floor pan repair kit.
Reviewed by: charles b from texas. on 1/30/2009
KBS Coatings
Ratings - KBS Coatings Amazing Cleaner
This liquid magic, is amazing. It helped me so much with cleaning out an old gas tank that belongs to an old truck I'm rebuilding. I am very pleased with the end results.
Reviewed by: Josiah from My home. on 10/2/2008
KBS Coatings
Ratings - KBS Coatings Works Great!
Works great for all kinds of nasty stuff accumulated under the car.
Reviewed by: Ludmil from salt belt. on 9/30/2008
KBS Coatings
Ratings - KBS Coatings Works GREAT with a power washer !
I used AquaKlean to clean and prep a motorcycle frame I was restoring. I used it first with my power washer to get all the old oil and dirt off and it did a great job of it. I used it again to prep the frame a day before I painted it and I am very happy with the way it cleaned the frame. AquaKlean is the best cleaner I ever used !
Reviewed by: Joe R. from West Covina, CA. on 9/2/2008
KBS Coatings
See All Reviews
Paint For Rust
Paint For Rust
KBS RustBlast
Paint For Rust
