High Temperature Paint
Home > Supplies Bookmark and Share
Average Rating KBS Coatings
KBS BackBone Reinforcing Mesh
A thin pliable reinforcing fiberglass mesh that lays flat to form an invisible patch made of unbeatable strength & holding power. Easy to use. No bunching, bulging or stiff loose hairs to ruin your finish. Use in conjunction with RustSeal or NuMetal to repair holes and bridge gaps in metal, wood or fiberglass.
$7.00
  • Experience the difference with KBS BackBone Reinforcing Mesh, a soft, thin, flexible, reinforcing fiberglass cloth with amazing strength and holding power.
  • Each packet contains 1 square yard of BackBone which is specifically designed to bridge gaps and repair holes and add a layer of additional security.
  • Apply BackBone to metal, wood or fiberglass using KBS RustSeal for unmatched protection and coverage. Your repair will stand up like a champion!
  • Please Note: There is one large piece of cloth in this envelope.
  • Do not handle mesh with bare hands. Always wear gloves when working with BackBone.
  • As you cut the cloth, fibers may fly into the air. Please wear a mask while cutting BackBone.
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings Perfect for the Beginner
Working with KBS Backbone was not just easy but also most satisfying. I am trying to repair a 1969 Jeep CJ 5 and the combination of this mesh and the KBS coating turned out to be a perfect match for my project. I had my 19 year old daughter watching me work and as soon as she saw my first application, she took over from me and completed patching all the holes on the floor. Her work turned out just like mine - par excellence! Thanks to KBS.
Reviewed by: Nasir Mohammed from Prairie View, IL. on 3/4/2008
KBS Coatings
Ratings - KBS Coatings laid flat
This stuff worked well. It laid out nice and flat and did not come apart.
Reviewed by: Brad B from Great Falls, MT. on 7/1/2006
KBS Coatings
Ratings - KBS Coatings nice & easy
I have used some mesh from other companies and it is always so hard and messy to work with. This stuff was easy to work with and ended up looking great.
Reviewed by: TomS from Memphis, TN. on 5/19/2006
KBS Coatings
See All Reviews
Paint For Rust
Paint For Rust
$110.00
Paint For Rust
KBS NuMetal :: Epoxy Putty
$19.50
