*Kit includes Black Lightning Gloves, a Piece of BackBone (Reinforcing Mesh), Brush and Stir Stick.
Working on a Tank with a Previous Liner? Our PLUS KIT contains a Quart of Strip to quickly remove failed sealers. Go HERE for the PLUS KIT.
The KBS Cycle Tank Sealer Kit contains everything you need to seal a tank of up to 5 gallons.
KBS Instructional DVD
Now you can get our helpful videos in pristine DVD quality, sent right with your order for only $0.95. This DVD includes eight episodes, showcasing our three most popular KBS products in everyday applications.
I ordered this stuff for my husband for his IH Cub gas tank. No one in town would touch the tank because it had a baffle. I found this stuff on google and it worked like a charm. The directions were easy to follow, transaction was flawless, and we had the product within 3 business days.
I highly recommend it.
Reviewed by: Elaine B. from Evans, GA.
on 7/2/2009
Very Happy!
I purchased the motorcycle kit to repair pinholes in my Ducati tank. It worked fantastically and I was shocked at how filthy the crud in the tank was. The cleaner is amazing. This product is very fairly priced and that helps when the paint repair to my tank required lots of $$$. Thanks so much for the great product. I will buy again!
Reviewed by: Todd M from Oak Ridge, NC.
on 6/30/2009
Very fast service and shipping.
Nice product. Fairly easy to apply....just difficult to see what you're doing inside the tank. Very fast service and shipping.
Reviewed by: Todd J from Oklahoma.
on 6/29/2009
It works !
First time doing this fix. I was actually surprised by the results. In a good way. It worked on an old Motorcycle gas tank. Bike runs and looks great inside the tank.
Reviewed by: Mike F from Newburgh, NY.
on 6/29/2009
Very easy
Used 3 step!! Worked great very easy.
Reviewed by: Larry D from Moore Haven.
on 6/29/2009
