Home > Restoration Kits
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS Cycle Tank Sealer Kit
$35.00
  • The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 5 gallons.
  • Quart of AquaKlean
  • Quart of RustBlast
  • 8oz. of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
  • Non-flammable
  • Environmentally safe
Can't say enough about this product   9/3/2008
I can't say enough about this product. I used it on a moped gas tank that is integral to the frame. So, it''s not like you can just replace the tank. It worked perfectly. I had a pretty good gas leak. Now, doesn't leak a drop. Thanks.
Reviewed by: Bob L from Spring Lake, NJ .
Motorcycle Doctor   8/31/2008
I have been working on bikes for thirty five years and have not until now found a product that works as well as yours does.I did have an extremely rusted tank last month that put your prduct to the test. I first cleaned it with muradic acid straight along with some pee gravel.Caution with this procedure because it can expand the tank if you seal it too well.After flushing that out I then did your three step kit. I have to say that I was VERY IMPRESSED with results.
Reviewed by: Pat T from Greenville, South Carolina.
HOLY CRAP THAT'S FAST   8/31/2008
Ordered Thursday morning-on my doorstep Friday afternoon! Kit worked great!
Reviewed by: Danny from Cleveland OH.
KBS Cycle Tank Sealer   8/30/2008
Great product, easy to apply and left the tank in great shape; almost LIKE NEW!
Reviewed by: Hector G from Lebanon, TN.
customer repair   8/30/2008
I had a customers tank that had a leak. Kit works GREAT! i will use again.
Reviewed by: Manfreds Equipment from Bernville Pa..
Cycle Tank Sealer Kit   8/30/2008
My tank was leaking through the side of the tank and I was worried I''d have to buy a new tank or take it come where to have it sealed$$$. A friend sent me to your web site. Was a little intimidated but did it and am I glad, glad I say I did because it looks like new inside w/no leaks. Thanks KBS you have a customer for LIFE.
Reviewed by: Bruce H. from Clermont Fl. .
Surprised Me!   8/30/2008
i was very IMPRESSED with the product. I've used other sealers before with bad results. the KBS worked wonderfully and was also easy to use. i would recommend it to ANYONE that needs to fix a leaky motorcycle gas tank...
Reviewed by: Rick from Alabama.
Good stuff   8/30/2008
This is the second time I have used your kit. FANTASTIC PRODUCT!
Reviewed by: John H from Lake Havasu City, Arizona.
Cycle Tank Sealer Kit   8/29/2008
I ordered the kit after having the rust in my tank repeatedly cause issues with the needle and seat in the carb of my 80 Honda CX 500. The kit WORKED WELL and haven't had a problem since!
Reviewed by: Glen H. from Rio Rancho, NM.
tank sealer   8/29/2008
nothing but GOOD PRAISE for this product. sealed bike tank nicely.
Reviewed by: marc from seattle wa.
Great Product   8/29/2008
Quick shipping and customer service. Product worked just as described. EXCELLENT!
Reviewed by: Peter N from Granby CT.
Best thing since the motorcycle. NO MORE RUSTY FUEL!
Reviewed by: Kenneth S from Cloverport, Kentucky.
It's All True   8/29/2008
Follow the directions, don't cut corners or rush it and it is amazing. Best DEGREASER I ever used also. BO08
Reviewed by: Jim B from Downers Grove, IL.
excellent   8/20/2008
Better than kreem and por-15 products. I just ordered 2 MORE KITS!
Reviewed by: captsizzle from Medina, Ohio.
Great   8/10/2008
Awesome product
Reviewed by: Kyle D from Stuart.
KBS CYCLE TANK SEALER   8/10/2008
It''s simple. It''s a NO BRAINER. Start off with a good tank, the bad tanks are your 2 to 3 star screw ups that either started out with a bad tank expecting miracles or didn't fallow the instructions. It''s simple, again, start off with a GOOD tank, not a rusted through hunk of rust or a busted piece of plastic, FOLLOW THE INSTRUCTIONS, do EXACTLY as said in the INSTRUCTIONS, let the tank dry and cure as suggested and go! HAVE NO DOUBTS! BUY KBS! NOT THE OTHER STUFF!!
Reviewed by: Skylar B. from Indianapolis, IN..
86 Honda cb700sc   8/1/2008
Buying a new tank would have been over 400$ direct from honda. This kit sealed all Problems with this tank...fantastic...worth every penny
Reviewed by: MIke L from Fond du lac WI.
No need to weld.   7/31/2008
Great stuff! Saved my brand new paint job.
Reviewed by: Steve from Bay point Ca,.
KBS Cycle tank sealer ROCKS!   7/31/2008
I used KBS on my 74 Honda CB 750. The inside of my tank was so rusty that it contaminated the fuel system and blocked the carbs. Since using KBS the inside of the tank looks great and I no longer have a problem with contamination in my fuel. I was concerned that the product would harm a new paint job, it did not! When I accidentally got some on the new paint I just washed it off with water and continued with the process. A super product! I plan to do the tank on my 76 Kawasaki 500 as well.
Reviewed by: Rick M from California.
Works quite well!   7/31/2008
In my many years of restoring motorcycles and VWs, I have seen some pretty bad tanks and repaired quite a few using different methods. The KBS three part kit is hands down the best, most complete and easiest to use of EVERYTHING I have tried. The results speak for themselves. KEEP UP THE GOOD WORK!
Reviewed by: Joe P from Red Rock, Texas.
Just what the doctor ordered   7/31/2008
I picked up an old bike that was laying around for a number of years. When I drained the gas tank the a lot of muck and rust came out. I picked up one of your kits and followed all of your instructions and the tank came out perfect. I have two other bikes and I''m going to coat their tanks over the winter with your product just as a precaution. I highly recommend your coatings to anyone who asks.
Reviewed by: Jerard B from Middletown NJ.
Great customer service   7/31/2008
I followed the instructions to remove a previous white sealer application. It didn't take it all out but the petcock nuts came loose. I had to cut the tank apart at the seam where the leaks were and will re fiberglass. Ben was very helpful and considerate. He allowed me to return the product. No Hassel!
Reviewed by: John G from Kenosha, WI.
BUY IT   7/31/2008
I used it on a 1984 kaw that was stored outside for 5 years. I had to braze up the larger holes first then I followed the directions and voila better than new.
Reviewed by: firedawg from MICHIGAN.
Better than anticipated   7/31/2008
Bought a 97 Honda Shadow which sat in a barn for 10 years. The tank was a disaster, coated internally with solid rust. Searched the web and found your product and being a coatings chemist it sounded like the answer. Followed the instructions and now I have a "like new" tank. Thanks KBS
Reviewed by: Denny R from Chesterland, Ohio.
KBS worked like a charm!   7/31/2008
After an accident on my bike, I had a small but steady leak somewhere on the bottom of the tank that I''d previously tried patching with some metal epoxy, to no avail. Heard of a product that seals the tank from the inside but didn't have a name to go buy, Googled for it and found KBS. I ordered the tank seal kit, followed the directions and haven''t had a problem since. I'd recommend it to anyone with the same problem, I''m very happy with how it worked for me.
Reviewed by: Gene from Bellevue, WA.
Cycle Tank Sealer   7/30/2008
Did not stop the leak all the way on my chain saw, but did slow it down.
Reviewed by: Paul W. from California mountains.
Holy Fucking Shit, This Stuff works as advertised!   7/16/2008
Works as advertised? Works better than advertised. A flexible impervious coating that is second to none. (Well, maybe teflon) I have a 1980 BMW that I was mulling over selling, restoring or throwing it in the shit can. Who wants to buy a new tank? The rest of the bike is excellent but the tank was full of rust chips so bad it was unusable. I carefully followed all directions to a "T" and it came out absolutely beautiful. If you are not blind and/or stupid, you can do this too.
Reviewed by: Patrick C from Salisbury, NC.
Never failed   7/5/2008
I own Strader Studio,LLC custom paint and airbrush shop. This is the only product I have used from new to old tanks as well as carbon fiber as well. So far its been absolutely GREAT
Reviewed by: Strader Studio,LLC from Houston,TX.
Old Tank, New Again   7/2/2008
Your product worked great? The Tank that I used it on was from a 1973 Honda motorcycle that many people said was hopeless. Thanks!
Reviewed by: Dwayne L from Richmond, VA.
Huge savings   7/2/2008
I used the cycle tank in my Honda eu3000 generator tank which is 9 years old, it worked out great and saved me $180.00 on the cost of a new gas tank.
Reviewed by: mary n from Alpine, Az..
Customer   7/1/2008
Awesome Product!
Reviewed by: Delaney D. from Stuart, Florida.
GREAT PRODUCT   7/1/2008
GREAT PRODUCT-VERY EASY TO USE TANKS LOOKS NEW THANKS
Reviewed by: DOUG A. from MEBANE NC.
Cycle Gas Tank Sealing Kit   7/1/2008
This is the second product of this type that I used, the first was Red Kote. Red Kote seemed to stop the rust in the tank, but it was causing the gasoline in the tank to turn red! So I ordered KBS and problem solved! Thank you KBS!
Reviewed by: Karl from Warren, MI.
Motorcycle kit   6/30/2008
I felt the kit was priced well and did the job. I was a little unhappy with how well the step 1 degreaser worked, I still had a lot of black stuff that didn''t come out with it, I ended up soaking the tank in a mild vinegar solution at around 180 degrees overnight. That seemed to do the trick. Then I proceeded with the etch and coating. Because the degreaser didnt work so well it took more time than I would have liked.
Reviewed by: Eon from milan, MI.
Fiberglass Tank   6/30/2008
Worked great, easy to use. For the first time i can run pump gas with ethanol in it without worrying about the gas eating into the tank
Reviewed by: Dave from Greentown,In..
kbs tank sealerI   6/5/2008
JUST FOLLOW THE STEP BY STEP INSTRUCTION,REALLY,YOU"R TANK WILL LOOK LIKE NEW,PERIOD
Reviewed by: allen c. from arlington,ma..
Rusty tank   6/2/2008
I found the product to be simple and effective.
Reviewed by: Larry w from Stevensville, mi.
Great Product   6/2/2008
I got the sealer for a rusty Yamaha tank, it worked great and the instructions were very easy to follow. Doing it was long, but it was worth the wait. I see a difference with my fuel filter and the system is cleaner.
Reviewed by: Brian from Provo, UT.
! ! ! ! ! THE BEST ! ! ! !   6/1/2008
Saved my 91 Kawasaki Zepher and 600$ the cost of new tank VERY GOOD STUFF ! ! ! !
Reviewed by: Roman from Trenton NJ.
Great product! Highly recommended!   6/1/2008
Great product! it would be nice to supply some sort of cork or plug for the petcock hole. Using duct tape only will not be strong enough to hold the juice around. I used some plastic shopping bags to make a big plug to seal the hole. Then I used duct tape to hold the plug from falling off. This seems to work. Please provide something similar with the kit, or revise the instruction so users can get their tank better prepared. Again great product! Highly recommended! Bought two!
Reviewed by: JIM from CA.
Fool Proof   6/1/2008
I used this on a gas tank I made from an old sportster tank, and even though I only had a 110 flux core welder and many little holes, the KBS kit worked wonders and I've been using the tank for months now with no issues. Easy to use and the highest quality sealer on the market....Bar none...........
Reviewed by: Big Ern from Fort Hood, TX.
Depends   5/31/2008
Good Morning, you may not want to submit this one. I followed directions and came up with more leaks than started I believe tank had more rust in it than expected. My tank actually leaked more. I am blaming the rust. I took an hour for each of the preliminary to dry. I gave it a week for the final. It looked ok. I think stripping the rust opened more holes. I ordered another tank and waiting for delivery .Your product seems good.Some combinations just don't work.
Reviewed by: D. Drumsta from 9184 Morse Rd E. Concord, NY 14055.
Good Product   5/31/2008
I had a tank with a lot of rust inside--about 25 years old, used your tank sealer and it worked great! Good directions and easy to use.
Reviewed by: Smitty from fredonia n.y..
Sealed my 82 Honda Gas Tank Leaks   5/30/2008
I''m impressed by this product. It sealed up my rusty 82 honda tank with ease. No leaks! I thought I would be needing a new tank for my old bike. Your product is worth the money spent! Thanks KBS!!
Reviewed by: Randy from Wisconsin.
New Custom Harley Gas Tank   5/30/2008
I searched & searched the internet looking for the "Right Stuff" and found it. I was very impressed with every facet of this cleaner/sealer. Just follow the instructions and your problem is over and your goal will be achieved. Don''t waist time buying some other inferior stuff. Do it Right. I don''t get impressed easy by anything so trust me, if I''ve taken the time to sit here and write this, I''m satisfied.
Reviewed by: Jerry A. from Cambridge, Ohio.
KBS tank and sealer kit on newly painted tank.   5/30/2008
I got the products which were very easy to follow and applied inside my newly painted tank. I read all the directions three times. I also noticed upon applying the rust remover it was very slippery and had to take extra precaution while rinsing my tank. Everything came out fine but make sure you rinse your tank out at least three or four times shaking as you go. I would recommend there products to everyone whether it be new, used or just painted to everyone. Thank you
Reviewed by: Paul from Denver, CO.
Great Product.   5/30/2008
I used the kit to restore a 1969 Triumph Bonni tank, and its like I have a brand new tank.
Reviewed by: Ryan from Hixson, TN.
best cycle tank sealer around   5/30/2008
I had bought a old cycle that has been sitting for 14 years! not running yet had old fuel in the tank(if you want to call it fuel) more like varnish this product cleaned it out removed a lot of rust and what was left the sealer coated tank perfectly best product on market easy to use and it works bottom line! beats paying 150 to 175 to have it done.
Reviewed by: Todd P. from Arlington Heights, Illinois.
product   5/14/2008
can you use this over a tank that has been creamed
Reviewed by: dan mc. from west lafayette ohio.
easy   5/3/2008
Kreem is crap, KBS is super easy to use and the tech support is phenomenal. i would recommended it 20 times over
Reviewed by: loghauler from suffolk virginia.
Gas Tank Coating   5/3/2008
Your product worked very well. The instructions were clear. My bike has run super for a 33 year old Honda. I wish I had saved some.
Reviewed by: Mickey S. from Alabama.
Beyond Excellent   5/3/2008
Wow, this stuff is great! Kreem who? Follow the directions, in particular about draining excess or keeping the tank moving if it doesnt drain well, let it dry for at least the recommended time. I am very, very impressed!
Reviewed by: Micahel H. from Tucson Az.
KBS cycle tank sealer kit   5/3/2008
The kit worked great old very rusty tank now looks new inside. Thanks for the great service
Reviewed by: Jim T. from San Antonio, Tx..
KBS   5/3/2008
My 76 kawasaki had pin holes and small surface rust. It has been over a year since its been coated, no peeling and still looks great. Better than Kreem....
Reviewed by: Bob from Home town.
Rusted 4-wheeler gas tank   5/1/2008
The sealer was easy to use and performed as advertised. Being from south Texas, I was a little concerned about the humidity factor, however it did not seem to effect the cure time too much. Much, much cheaper than a new tank.
Reviewed by: T. Ed from Alvin, Tx..
tank sealer kit   5/1/2008
i wouldn't recommend anything else but kbs tank sealer kit. the inside of my tank (1993 zx7)was full of rust, now it looks like it haven't been used. thank you.
Reviewed by: brian b. from downingtown, pa.
KBS Cycle Tank Sealer Kit   5/1/2008
The motocycle tank I had to seal had already been sealed before but was leaking around the welde flange. It was recommended to me by KBS to strip out the old sealer. I soaked the inside of the tank with Methylene Chloride for 3 days then used a pressure washer on it. This got out what I thought was all of the old sealer until I used BBS 3 part kit. The Aqua Klean and Rust Blast removed even more old sealer that I didn't know was left. Amazing stuff. Now the tank is sealed and no leaks!
Reviewed by: Mac from Dracut Ma.
Great Product   4/9/2008
Worked great
Reviewed by: G from Troy, MI.
works so far   4/5/2008
Put it in a new tank and it works so far
Reviewed by: Jeff M from Middleburg VA.
worked great on my 1969 triumph   4/5/2008
Your product worked very well and sealed a 1/32 hole that I managed to poke into a newly painted tank. This product is so much easier to use than the old "Cream" that I used in the past.
Reviewed by: Jeffrey C. from CINCINNATI OHIO.
OSSA fiberglass tank   4/4/2008
The kit worked as advertised and salvaged yet another vintage tank from the scrap heap. Today''s gasoline/oils are not kind to vintage fiberglass...your sealer solved the problem. Thanks.
Reviewed by: Patrick D. from Easley, SC.
GReat gas tank sealer   4/3/2008
This product was used to seal a mini chopper gas tank, and the product works great.
Reviewed by: Blake from Vacherie,La.
New Tank   4/2/2008
Remarkable product! Easy to use! I purchased a new tank for my Sportster and wanted to keep the rust out, this is by far the best. My painter uses "the other stuff" and i do believe he will be switching to this, he was amazed at the outcome. Keep up the good work.
Reviewed by: Dave from LA (Lower Alabama).
good stuff   4/2/2008
I re-lined the tank at about 40 degrees - which wasn't recommended - and it was a pain getting the urethane to coat the entire tank. Then it required hours of moving the tank around to prevent the small amount that wouldn't drain from pooling... but it worked great in the end.
Reviewed by: Colin from Raleigh, NC.
GREATTTTT   4/1/2008
I got it hoping it would work well and worked perfect. I just had rust in the tank no holes so it was easy to do it took awhile but it was worth it. I just did not want all that nasty stuff in my gas
Reviewed by: Joe from Leominster MA.
new tank   4/1/2008
i used it in my new tank so it would last longer and seal it. easy to use and a good value to. harley wanted 40for their kit just to a small tank.
Reviewed by: matt from beaver dam WI.
Tank sealer   3/9/2008
The product worked as advertised sealing the leak in my 1980 Suzuki fuel tank.
Reviewed by: Dennis M. from Monroe GA.
a no-brainer!   3/6/2008
Simple, easy to use,and ,best of all, it WORKS!!!
Reviewed by: arlyn m. from illinois.
Great Kit!   3/5/2008
Worked great. A lot cheaper than buying a new gas tank. Used for my 1980 Troy Built tiller metal tank. Thanks!!
Reviewed by: Duane from Lyndonville, VT.
One kit repaired two motorcycle tanks and a spare auxillary tank   3/5/2008
I was able to use and re-use the cleaning and prep system to clear out and prep two motorcycle gas tanks and one small, auxiliary tank as well. The actual liner was more than capable of covering the inside each tank completely. I swear I could have coated another...but that would have been insane. : ) I wouldn''t normally wouldn''t attempt to do several tanks at once, but this was an emergency and this stuff performed admirably. Thank you. David
Reviewed by: Outersketcher from Fullerton, California.
Worked as advertised   3/4/2008
Worked as advertised on my 1979 Trail 90. Great stuff!!! Woody
Reviewed by: Jim W. from Texas.
Very pleased   3/4/2008
It kept me from buying a new tank. It brought a tank that had gas sitting in it for 22 years complete with varnish and rust back to like new condition. Well worth the money!
Reviewed by: Bob S. from Chattanooga.
Great product and customer service!   3/4/2008
Went down on my motorcycle, and my tank had a little seam leak that the sealer patched right up and is still holding strong!
Reviewed by: Chris from Austin, TX.
The products worked great.   3/4/2008
The products worked great. I was able to clean out 30 yrs. of rust on a steel tank. Just follow the directions and take your time. I will use it again on my other "classic" bike.
Reviewed by: Mike M. from Austin, Texas.
First time user   3/4/2008
This was the first time I have ever used a tank sealer. This kit was so easy to use, I don''t think there is any reason to even give another product a try. Plus it cost me less to order this product online than to drive (gas) and pick up Kreem from the closest dealership.
Reviewed by: Tom from Apex, NC.
Motorcycle Tank Sealer   2/15/2008
I used this product on my Honda cb750 tank and was completely satisfied with the results. The instructions were easy to follow and the results were amazing. The inside of the tank looks brand new. The best part is no more fuel line clogging problems.
Reviewed by: John from Moscow Mills, MO.
Better than expected!   2/5/2008
The three step process was easy enough to follow and the tanks look great. I used one quart of the coating to line two scooter tanks. It said it could do one 5 gallon tank, and the scooter tanks were 1 and 1.5 gallons. I didn''t experience any problems with this variation. I have already recommended it to some friends that need to do the same for their old scooters. It was so much cheaper than buying new tanks.
Reviewed by: Hudson from Denver, CO.
No Leaks   2/4/2008
Worked Very Well!! Sealed many rust holes some 1/16" big! No leaks, Very happy ThanX
Reviewed by: mxrayser from Orange County, California.
owner   2/3/2008
We used it to for m/c tank, worked great.
Reviewed by: Robert L from Katy tx.
KBS Cycle Tank Sealer Kit   2/2/2008
Great product, easy to use, clear directions. Worked great. Saved me over $200 dollars. Highly recommended.
Reviewed by: Gerald from Virginia Beach, VA.
customer   2/2/2008
This product seemed to get the job done. It''s winter, so i haven''t refilled my motorcycle gas tank back up, but it seems the product did a hellova job! Thanks guys!
Reviewed by: Cory M. from Ohio.
works great   2/2/2008
product worked great. instructions easy to follow and perform. no brainer made my motorcycle rideable for a fraction of the cost of a new tank
Reviewed by: l minnick from zephyrhills,fl.
great product   2/2/2008
worked great on new fat bob tanks...just needed another can of sealer for second side.
Reviewed by: C. Smith from Arkansas.
1954 BSA tank restored!!   2/2/2008
WOW!! Great stuff,works as advertised.I will order it again for my next project. Great customer service ,answered my questions rapidly.Thanks, John G.
Reviewed by: John G.II from Saint Petersburg.
KBS Works fantastic!   2/1/2008
KBS Rocks! I used it to fix a rusting problem in my Honda CB 750-4. The inside looks new and I did not have to worry about my fresh paint being ruined. I plan to use your kit on my Kawasaki triple as well when I get ready to paint it this Spring. Thanks for a great product.
Reviewed by: Rick M from Lincoln, CA.
PRES   2/1/2008
THANKS GOOD PRODUCT
Reviewed by: v. o. from WILTON CT.
cycle tank kit   1/30/2008
Product was easy to use and worked as advertised.
Reviewed by: Robert F. from Montgomery,TX.
Saved my BeHind   11/25/2007
It just plain WORKS
Reviewed by: Robin J. from Ashley, MI.
KBS Motorcycle Tank Sealer Kit   11/12/2007
EXCELLENT!!! The best that I have used!!
Reviewed by: Pappy Z from Ord, NE.
Tank Sealer Kit as advertised   11/4/2007
Excellent service. Prompt shipment, good packaging. Sealer left a thin, sandable surfact that blended well with the tank when I used it on the outside.
Reviewed by: Harry B from Utica, OH.
KBS Motorcycle Tank Sealer Kit   11/1/2007
Just pro`s--kit came quickly, directions were easy to follow, process just as easy, with good results. By the way, I used lanolin hand soap to fill threaded portions to keep sealer out of them. Worked well.
Reviewed by: Victor S from Winter Haven, FL.
Motorcycle tank kit   11/1/2007
KBS worked just as advertised on my old Honda fuel tank. I was nervous about getting any on my fresh paint job. But all I had to do was rinse it with water. Well worth the price! I plan to do another classic soon. Great money saving product!
Reviewed by: Rick M from Pickens, WV.
MotorCycle Tank Sealer Kit   11/1/2007
Worked real well, just like it said. Tech help was good and very helpfull.
Reviewed by: JIm L from Abelene, TX.
Motorcycle Tank Sealer   11/1/2007
Easy step-by-step process that really works well.
Reviewed by: Jack W from Chicago, IL.
not so good   10/16/2007
The directions were clear and the product was easy to use.
Reviewed by: James K from Hammond, IN.
great kit   9/12/2007
easy to use, great instructions,for best results let stages dry overnight, rust blast worked excelent, sealer cleaned up easy while still wet
Reviewed by: Duane H from Brownwood, TX.
Works great   9/6/2007
With nothing tocompair it with I have to say this is the best product I have ever used. it sealed off my rusty tank and found leaks I didnt know where in it. Buy it if you need to repair your tank
Reviewed by: Robert B from Graham, NC.
Cycle Tank Project   8/2/2007
I restored a 1968 tank with about 8-10 pin holes. The process was difficult considering the number of pin holes I had but the instructions were clearly laid out. Overall, the product worked very well and the tanks been holding gas now for a couple weeks without issue.
Reviewed by: Mark J from Ord, NE.
SIMPLE!   8/2/2007
Tentative about product being able to support its` claim. Read directions, followed directions and results were exactly as stated. My used 4-Wheeler now runs without carbureator clogging issues due to rusted Fuel Tank. SIMPLE!
Reviewed by: Tony D. from Fort Dodge, IA.
Gold Standard motorcycle liner   8/1/2007
The natural silver looks so much better than competitors` repaired looking colors. This stuff is nasty tough and remains flexible - huge advantages over Kreem. These are really important advantages for off-road applications.
Reviewed by: Jon M from St. Augustine, FL.
KBS gets a 10 out of 10!   8/1/2007
Everything went fine! The kit was great and the product works!
Reviewed by: Mike from Woodbury, TN.
Small Tank Sealer (Liner)   8/1/2007
I was cautioned to follow the detailed instructions if I want the best for all my effort. I did exactly what the step-by-step instructions said and am absolutely delighted in the results. I allowed plenty of time (approximately 1-day) between steps which, I believe, contributed to the success of the procedure. I also allowed approximately 3-days before I put fuel in the tank. Every time I look into the tank, knowing what it looked like before, I can hardly believe it’s the same tank. It looks like new.
Reviewed by: Dennis S from Florence, SC.
Happy Customer   8/1/2007
Very easy too use. Easy directions. Requires very little skill.
Reviewed by: Keith S. from South Barrington, IL.
Saved my bike!   8/1/2007
I HAVE A 1970 HONDA MOTORCYCLE. THE FUEL TANK WAS A RUST BUCKET. YOUR TANK SEALER FIXED IT PERFECTLY. I NOW USE THE BIKE DAILY. GREAT PRODUCT...THANK YOU.
Reviewed by: Doug from Provo, UT.
Great stuff at a Good Price!   8/1/2007
EASY! Doesn`t take forever to set up. Saves buying a new tank. Worked great on my old rusty thing and now I don`t have gas leaking all over my garage.
Reviewed by: Eva S from Eubank, KY.
KBS MotorCycle Tank Sealer K   8/1/2007
Works great. Looks great. No suprises. Works as advertised. Used Kreem before and found KBS tank sealer kit a lot easier and less messy to work with. The fumes from the Kreem actually softened the paint on my tank. Noting like that experienced with KBS tank sealer. Highly reccomended ! No BS.
Reviewed by: Ken P. from Valdosta, GA.
