Home > Restoration Kits
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS Frame Coater Kit
Our quart size 3-Step System kit includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coat paint coverage. DIY protection at a tremendous value! Detailed instructions included.
$55.00
Color:
KBS 3 Step System
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
  • The KBS Frame Coater Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 50 square foot area.
  • KBS Coatings’ 3-STEP SYSTEM of RustSeal (a rust preventive coatings), KBS AquaKlean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today.
  • Quart - AquaKlean
  • Quart - RustBlast
  • Black Lightning Gloves
  • Two Brushes
  • Stir Stick
  • All orders are just $8.00 Shipping
Excellent Products   6/30/2008
I bought the frame kit for the refinishing of my boat trailer. Very easy prep products and a quality finish coat. Being a painting contractor, I have dealt with many coatings and this company sells one of the best. Thanks for a great product!
Reviewed by: SS from Rolling Meadows, IL.
KBS Coating Satin Black   5/30/2008
Very Easy to prep and to apply product. The finish product is very hard and durable . I have tested the coating by hitting it with a hammer and did not chip or crack.
Reviewed by: Dale from Rosebud, Missouri.
1992 Jeep   5/4/2008
Had a rusted out frame on a 1992 Jeep, appears to have done a great job, looks real good. Great people to work with...
Reviewed by: Ed G. from Virginia.
Great Rust Control   5/1/2008
Having my travel trailer on the gulf coast, I was never able to find anything to stop the rust on the frame. That was until I found KBS Frame Coater. It works great. Just wish I would have had it when I was chipping paint in the Navy.
Reviewed by: Roy B. from Texas.
Awesome stuff!   4/2/2008
A little goes a long, long way - the coverage and level properties were excellent. Highly recommended.
Reviewed by: Craig L. from Flint Hill, VA.
Old rusty frame   4/1/2008
This stuff is better than awesome. I like it. I used the other stuff on another frame, but I won''t use that again. I''m sold on KBS. They guys stand behind their products with superior customer service. They responded to a problem I had with their epoxy immediately!!
Reviewed by: Charlie R. from Scottsdale, AZ.
Awesome utility trailer refinish job.   10/7/2007
The frame kit was just the right amount of each product to clean, treat and refinish the rusted structure of my utility trailer. It looks great-was easy to apply and is rock-hard.
Reviewed by: Donald G. from Woodbury, TN.
Lives up to the Claims   7/5/2007
Very satisfied with results. I started with a sandblasted boat trailer. I used a brush for all of the coating and it dried to a smooth, very hard, professional looking finish.
Reviewed by: Denny B from Eubank, KY.
frame coater kit   3/4/2007
very fast service. Much quicker then stated.
Reviewed by: Scott L. H. from Portland, OR.
Frame works   1/5/2007
Great product, so easy to use, followed the step-by-step directions and it looks new again. I will definately use more KBS products.
Reviewed by: Jamie B. from San Diego, CA.
Excellent   12/6/2006
I rate your product as excellent. I like the way it covers & levels out after application.
Reviewed by: Tony M. from Madison, WI.
Refinishing PLow   12/6/2006
Excellent Product. I would highly recommend it to everyone. Its holing up stronger then the previous powder coating finish that "was" on the plow. GREAT PRODUCT!
Reviewed by: Nick L. from Detroit, MI.
Great Stuff!!   12/5/2006
This stuff is GREAT, Absolutely great. My jeep frame turned out so nice, I almost hate to put the body back on it!
Reviewed by: Shoe C. from Charlotte, NC.
Ideal kit!   11/18/2006
Found this kit to be just what I needed for my project. The rustseal flows out so smooth everyone thinks its been sprayed on. Thanks guys.
Reviewed by: Rick W. from Dallas, TX.
shed floor   9/13/2006
I used this kit on my shed floor. It worked perfect. It seems to be holding up really well.
Reviewed by: Keith S. from Houston, TX.
Wow   8/17/2006
Wow. What a deal. I ordered it and received it the next day. It does what it says it will do. I like getting all that I need in one kit.
Reviewed by: RayC. from Florence, SC.
powder coating   7/15/2006
My friend told me that the Rustseal would be like powder coating, but I had my doubts. Well, it looks like powder coatings. This stuff is awesome.
Reviewed by: Kirk W. from Adell, WI.
Knockout kit   5/20/2006
Cleaner works, prep works, paint laid out nice, dries super hard! Impressed my friends too. Highly recommend.
Reviewed by: J. H. from St. Augustine, FL.
 Add Review KBS Frame Coater Kit
Review Title:
Review:
Rating:
= Required
