Home > Self Etch Primers
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS Fusion - Self-Etching Primer
This terrific NEW all-purpose self-etching-primer is ideal for promoting adhesion between multiple surface coatings (including applications of topcoats or primers over cured KBS RustSeal) in addition to priming bare metals such as steel, brass, aluminum, and most hard plastics.
15oz. Aerosol - $21.00
Pint - $26.50
Quart - $41.00
Gallon - $130.00
5 Gallon Pail - $565.00
$0.00
Size:
Looking for a FAST drying and easy-to-apply primer that allows you to quickly topcoat RustSeal or any other basecoats? We have exactly what you need…FUSION!
  • All-purpose grey self-etching primer ideal for promoting adhesion between multiple surface coatings, including applications of topcoats & primers or over fully cured RustSeal. Fusion is also excellent for priming bare metals such as steel, brass, aluminum and most hard plastics.
  • Allows you to topcoat over a smooth rock hard RustSeal surface that’s been in place for months or years! Just lightly sand the surface using 280-320 grit sandpaper before applying a thin covering coat of FUSION then topcoat as desired.
  • Can be sprayed or brushed on almost any painted surface and is ready for a topcoat in 20-30 minutes. Fusion is available in a convenient aerosol as well as pints, quarts & gallons. Satisfaction guaranteed!
  • All-purpose self-etching primer
  • Promotes adhesion to almost anything
  • Bonds to fully cured RustSeal
  • Ready to topcoat in 20-30 minutes
Note: not a high build primer
  • 15.2 oz. of Fusion will cover 40 sq. ft. with two coats.
  • A Pint of Fusion will cover 50 sq. ft. with two coats.
  • A Quart of Fusion will cover 100 sq. ft. with two coats.
  • A Gallon of Fusion will cover 400 sq. ft. with two coats.
  • A 5 Gallon Pail of Fusion will cover 2000 sq. ft. with two coats.
  • Click HERE for KBS Fusion SEP Application Information
worked great   4/6/2007
This stuff worked great. It was cured within 15 minutes and I was able to slap my topcoat on.
Reviewed by: Wyatt B from Winslow, AZ.
 Add Review KBS Fusion - Self-Etching Primer
Review Title:
Review:
Rating:
= Required
