Work Gloves
DF Clear Coat
DF Top Coat
Hi-Temp
Support & Assistance
Home > Self Etch Primers Bookmark and Share
Average Rating KBS Coatings
Reviews Write A
Review
Read Reviews on KBS Coatings Read
Reviews
Email Friend about KBS Coatings Email
Friend
KBS Fusion - Self-Etching Primer
This terrific NEW all-purpose self-etching-primer is ideal for promoting adhesion between multiple surface coatings (including applications of topcoats or primers over cured KBS RustSeal) in addition to priming bare metals such as steel, brass, aluminum, and most hard plastics.
15oz. Aerosol - $21.00  |  Pint - $26.50  |  Quart - $41.00
Gallon - $130.00  |  5 Gallon Pail - $565.00
$0.00
Size:
Looking for a FAST drying and easy-to-apply primer that allows you to quickly topcoat RustSeal or any other basecoats? We have exactly what you need…FUSION!
  • All-purpose grey self-etching primer ideal for promoting adhesion between multiple surface coatings, including applications of topcoats & primers or over fully cured RustSeal. Fusion is also excellent for priming bare metals such as steel, brass, aluminum and most hard plastics.
  • Allows you to topcoat over a smooth rock hard RustSeal surface that’s been in place for months or years! Just lightly sand the surface using 280-320 grit sandpaper before applying a thin covering coat of FUSION then topcoat as desired.
  • Can be sprayed or brushed on almost any painted surface and is ready for a topcoat in 20-30 minutes. Fusion is available in a convenient aerosol as well as pints, quarts & gallons. Satisfaction guaranteed!
  • All-purpose self-etching primer
  • Promotes adhesion to almost anything
  • Bonds to fully cured RustSeal
  • Ready to topcoat in 20-30 minutes
Note: not a high build primer
  • 15.2 oz. of Fusion will cover 40 sq. ft. with two coats.
  • A Pint of Fusion will cover 50 sq. ft. with two coats.
  • A Quart of Fusion will cover 100 sq. ft. with two coats.
  • A Gallon of Fusion will cover 400 sq. ft. with two coats.
  • A 5 Gallon Pail of Fusion will cover 2000 sq. ft. with two coats.
  • Click HERE for KBS Fusion SEP Application Information
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings KBS Fusion
We live in an older home. All the hardware on the front door is solid brass (over 60 years old). You can imagine trying to make these look like brass. Using the Internet I came across your product, KBS Fusion. It looked like just the thing I was looking for. And it was. Following the directions I was able to paint the old brass where now it looks like beautiful brand new brass! All I can say is thanks. BJ
Reviewed by: BJ Johnson from Selma, AL. on 4/30/2010
KBS Coatings
Ratings - KBS Coatings Very Impressed
I am building an experimental airplane and am using the Fusion self-etching primer on the smaller part. I'm impressed how evenly it goes on and the end result. You've got a good web site and your order turn time was excellent. I'm sure I'll be placing additional orders in the future.
Reviewed by: Donald K from Watford City, ND. on 10/28/2009
KBS Coatings
Ratings - KBS Coatings worked great
This stuff worked great. It was cured within 15 minutes and I was able to slap my topcoat on.
Reviewed by: Wyatt B from Winslow, AZ. on 4/6/2007
KBS Coatings
See All Reviews
Paint For Rust
$109.95
Paint For Rust
Paint For Rust
BlackTop :: Chassis Paint
