High Temperature Paint
Home > Tank Sealers Bookmark and Share
Average Rating KBS Coatings
A great 3-Step cost savings kit designed for the repair of motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
$39.00
*Kit includes Black Lightning Gloves, a Piece of BackBone (Reinforcing Mesh), Brush and Stir Stick.
Working on a Tank with a Previous Liner? Our PLUS KIT contains a Quart of Strip to quickly remove failed sealers. Go HERE for the PLUS KIT.
  • The KBS Large Cycle Tank Sealer Kit contains everything you need to seal a tank of up to 12 gallons.
  • Quart of AquaKlean
  • Quart of RustBlast
  • Pint of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
  • Gold Standard Tank Sealer can withstand temperatures of up to 500° F.
  • Non-flammable
  • Environmentally safe
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings kbs works
my '83 suzuki tank was full of sludge when i got it after alot of pre-cleaning and then using your product, it looks like new, thnx for a wonderful, easy to use sealer
Reviewed by: glenn from south jersey. on 12/29/2009
KBS Coatings
Ratings - KBS Coatings 1961 Jeep gas tank
The old tank in my snow plow was so rusty I was using a tank in the bed of the truck. This product was easy to use, cleaned the tank and sealed it. I have not had any trouble with it. It has been 6 months so far and so far so good. These old tanks are no longer avaliable and saving them is a great thing. In town the local radiator shop wanted 150.00 so this 50.00 investment was worth it. Thanks Roger Odle
Reviewed by: Roger Odle from Spokane Wa.. on 12/28/2009
KBS Coatings
Ratings - KBS Coatings Cycle Tank Sealer Kit
While the sealer seemed to work well, the Aqua Clean and Rust Blast didn't work nearly as well as phosphoric acid.
Reviewed by: Ken W. Ward from Orlando, FL. on 12/28/2009
KBS Coatings
Ratings - KBS Coatings Tough Stuff!
This kit comes with everything you need and works VERY well. Only problem I had, which was user error was that I let the final step get onto the latch for the top of my gas tank and when I tried to open it I snapped off the key inside. This again was my own fault as I let it get up there and let it dry. Good job guys, great product!
Reviewed by: Andy from Atlanta, GA. on 12/28/2009
KBS Coatings
Ratings - KBS Coatings customer
I got the large cycle tank kit for a tractor tank because it was rusting and making the tractor quit running. Your tank kit was easy to use and did an excellent job sealing the tank. I have not had any problems with the tractor since sealing the tank. Thank you for the great products you make. I will definently use your producys again.
Reviewed by: Michael J. Reksc from Northville. on 12/7/2009
KBS Coatings
See All Reviews
Paint For Rust
KBS Cycle Tank Sealer Kit
$35.00
Paint For Rust
$44.95
Paint For Rust
Auto Fuel Tank Sealer Kit
$59.00
