Home > Restoration Kits
Average Rating
Write a Review or See Reviews
Email this page to a friend
A great 3-Step cost savings kit designed for the repair of motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
$39.00
  • The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 12 gallons.
  • Quart of AquaKlean
  • Quart of RustBlast
  • Pint of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
  • Non-flammable
  • Environmentally safe
1933 Ford - WORKED GREAT   9/3/2008
Product worked great I had A lot of rust cleaned up well and sealed seems to be as good as new.
Reviewed by: Jim M from Centre Hall Pa.
KBS Large Cycle Tank Sealer   8/30/2008
Very nice product.....EASY installation instructions.
Reviewed by: Kevin from Michigan.
frame gas tank   8/28/2008
KBS did the job for me, i had to seal a gas tank that is a 2 inch tube in the shape of a J about 3 foot foot long. It was a 1980 Columba inperal moped.
Reviewed by: Allan R from Lafayette IN.
GREAT PRODUCT   8/3/2008
I bought this for my husband to fix his motorcycle gas tank, after a local screwed up trying to weld it. It was a worthwhile product, and very easy to use. We were very impressed how easy it was to do and how well it worked. We are firm believers of your product.
Reviewed by: Navia M from Greensboro Bend ,Vt.
GREAT STUFF   7/31/2008
GREAT STUFF EASY TO USE....SIMPLY TO FOLLOW INSTRUCTIONS WIT PROFESSIONAL RESULTS....WILL DEFINITELY USE AGAIN.
Reviewed by: PAUL T from WATAUGA , TX.
Tank sealer kit   7/31/2008
I used the large cycle kit to seal the tank on a John Deere LA small two cylinder tractor. The tank had rust that restricted the fuel flow. I cleaned out the loose rust and then cleaned and sealed it. Seemed to work well. Thanks.
Reviewed by: Adam from Barker, NY.
Great product does what it claims!!!   7/31/2008
I found the product and instructions easy to use. It does require time to apply to make product work properly. I would order this product again. The product does what they claim. I restored a BSA motorcycle tank that was 40 years old.
Reviewed by: Jim J from Macomb, Michigan.
Good Stuff   7/30/2008
I used the large kit for two motorcycle tanks. Halved the quantities for each process and had plenty to go around. I added a dozen pennies to the cleaner to break up extra rust. The sealer provides plenty of working time and there was ample quantity. Looking into the tank, it looks factory finished. Unlike the ugly "cream" stuff.
Reviewed by: Chris H from Boaz, AL.
Easy to use   7/30/2008
It worked as advertised and was easy to use. Just follow the instructions. Great product!
Reviewed by: Lynn from Ogden, UT.
Wonderful   7/1/2008
Overall... very pleased, final job was just what I was hoping for. The cleaner and rust blaster did do their job. However, I was not satisfied so I went and did it again with my own acid materials be of my significant rust. Then I used the sealer and the final results were just fantastic.
Reviewed by: Barry Deliduka from Burlington, Vermont.
Excellent   7/1/2008
Repair ATV tank that was rusted and full of pin holes. Easy to use and it did the job. Machine is being used now.
Reviewed by: Richard Rosenlof from Wisconsin.
Large Motorcycle Tank Sealer Kit   7/1/2008
I got the Large cycle tank kit. It was Enough to to do both tanks on my Honda 450 and Honda Trail 90. Did an excellent job on both tanks. I would definitely buy this product again. Thank you KBS!!
Reviewed by: Ken Berrian from Seattle, Washington.
AMAZING!!!   7/1/2008
I have a Ducati 900 SS and have had some issues with a slow leak on my tank for about a year. Tried a few other brands and always came up with the same problem.....a slow leak!.... a friend told me about KBS so I gave it a try before I spent a grand on a new tank (that I was going to do) Well KBS worked like a champ!!! Easy to use and NO LEAKS Thank You KBS
Reviewed by: Keven from AZ..
great product   6/30/2008
Did everything it claimed to do. Will definetly recommend to others!
Reviewed by: Jim M from Gillette Wy.
So far, so good!   6/30/2008
Application was easy and results appear to be good. But I want to wait for six or twelve months to see how the sealing holds up. Four stars is sort of an arbitrary rating at this point.
Reviewed by: Dave from Massachusetts.
Gas tank sealer Large   5/31/2008
Easy to use comprehensive directions. I have no leaks and think the product work very well!
Reviewed by: Ryan Wright from USA Colorado.
KBS coating   5/30/2008
it is over requirement product. I buy one kit and cover for two gas tank Honda. Recommend for you to buy it. Wonderful product
Reviewed by: Tu Nguyen from Florida,USA.
Good Product   5/30/2008
Very good product and simple to use, I sealed the tank on my project bike I took my time and got very good results.
Reviewed by: Randy G from Pelham N.C..
As good as their word   5/30/2008
This product does exactly what the manufacturer says it will , just do your part and follow the directions and you will get great results . I can't think of a better complement for any product .
Reviewed by: Chris Slay from Brandon ,MS.
Worked for me!   5/30/2008
After searching for an affordable replacement tank for my 2000 Suzuki Marauder''s leaking gas tank, I decided to try your product. It worked great! My tank is sealed and I''m back on the road again! Thanks KBS!
Reviewed by: Rob Catalano from Long Valley, NJ.
Great Stuff   5/6/2008
I used this on my motorcycle tank after I split it in half and made it wider. This stuff works great.
Reviewed by: Erick from Auburn Hills, MI..
great product   5/4/2008
I wanted a bigger gas tank for my Shadow, so I bought one from ebay, cut it open and welded in extra metal. Of course the welding was not perfect so I used kit to seal the tank. So far no leaks.
Reviewed by: Robert from s.c..
tank sealer   5/2/2008
It has performed as advertised and sealed all my pin hole leaks.
Reviewed by: tom c. from 211 orchard grove rd-campobello,sc.
Perfect   5/2/2008
Very surprised with how easy and effective this product is!
Reviewed by: Andrew S. from Avondale, AZ.
Good Stuff   5/1/2008
Don't waste your time with anything else, you only have one tank to coat, follow the directions and you have a new inner tank. Good Stuff
Reviewed by: Jm from Arizona.
Found the Solution with KBS!!!   4/1/2008
The product was fantastic! Good instructions made the process easy. The fuel system has never worked better for our Datsun fairlady. No more problems!! Thank you very much.
Reviewed by: glee from AZ.
Large Tank Sealer Kit   3/16/2008
I finally found the time to do the application,it was easier than it sounded.Has seemed to adhere well to tank,has not dried completely yet.Did last night.Used BBs instead of chain to remove rust.I believe I`m Happy.THANKS
Reviewed by: Doug W. from Burnsville MN.
EXCELLENT   3/4/2008
ordered the large tank kit and had it 2 days later. easy to use and worked like a charm. i will be ordering again. thank you.
Reviewed by: Trent L. from ohio.
Manager   3/4/2008
I ordered the KBS Large Cycle Tank Sealer Kit for my 66 VW Beetle gas tank at the beginning of December. It coated as easy as the instructions said and I''ve had no problems to date. I am very pleased with this product
Reviewed by: Don D. from Seattle, Washington.
tank sealing   3/4/2008
This product works very well, I was a first time user so I did not have a lot of experience to draw on. I was building a custom chopper from the ground up and had a lot of time invested in making the gas and oil tanks so I was very happy when I was able to seal both without any problems. I would recommend this product to any one. Thank You SL Lacy
Reviewed by: Steve L. from california.
great product   3/4/2008
used the large cycle kit on a built in pulling truck fuel tank from the inside. it worked great even with a brush !
Reviewed by: thunderstruck from Springfield tn.
Pearson, GA   2/14/2008
Product worked as described, easy to follow directions with desired results. Thanks for being there.
Reviewed by: Shelly C. from 463 Hubert Rd..
Great Sealer   2/6/2008
Great product. The kit provides everything. I "cheated", I had two 10 gal Fiat tanks and did both with one large cycle kit. Reheated cleaner for second tank. Flushed well. Dried well. Tanks didn''t drain well so drained sealer as well as possible and continued to rotate for two hours intermittently. Thanks!
Reviewed by: David B. from Western PA.
old white guy- motorcycle rider   2/4/2008
shipping was fast , the price was low and the stuff worked great. the paint was of particular interest since i have never seen anything like it. It was the only way to save the tank and it worked great
Reviewed by: gordon b. from san jose.
first time user   2/2/2008
I built a custom V-twin Motorcycle and this was the first time I sealed any kind of a tank.this product is very easy to use and the directions were very easy to follow. the motorcycle kit had enough product to seal a 2.2 gal. gas tank and a 6 qt. oil tank with a little left over. I would recommend this tank sealer it works
Reviewed by: SL Lacy from Needles,CA.
Owner   2/2/2008
Excellent result with coating on old BSA ... could have used a larger supply of the Rust Blast in the cycle kit .. excellent customer service and shipping, even with the Christmas holiday! Recommending to friends and associates.
Reviewed by: John M. from Kendall, FL.
Great Product   2/2/2008
Used this on the gas tank of a 1965 John Deere 1010 tractor. Once I got the tank off, followed the directions, had a little patience, the product is working perfect. No more rust flakes or partial fuel line blockage. Would recommend it over and over. Thanks, Ed
Reviewed by: Ed McK. from St. Augustine, FL.
KBS Tank Sealer   11/2/2007
Great Product! I used it to seal a Motorcycle Tank!! I have used Kreem in the past many times. It is a good product, but I will not ever use again since I have found KBS. KBS does a first rate job at sealing a tank and at close to half the price of Kreem! The other thing I truly like is its color. It is silver and really almost disappears when used and looks just like the metal inside of a gas tank!!
Reviewed by: Gary K from Portland, OR.
large cycle tank   11/1/2007
kbs coating is the best it saved me lots of money and problems thanks i will recomend it to anyone
Reviewed by: chris j from Norman, OK.
Just what my chinese mini chopper tank needed   11/1/2007
Tank was extremely filled with rust.After using the cleaners rust was gone.Sealer worked like a champ,No more clogged fuel filter and no more dirt in carb.Customer service was awesome,when I had problem with shipper I got a call from KBS rep to help fix the problem.Have recommened KBS to all my friends.FAST SHIPPING.Thanks
Reviewed by: Bob I from Los Angeles.
Tank Sealer Kit   10/9/2007
Great service. Kit was exactly as promised and worked to perfection.
Reviewed by: William B. from Billings, MT.
1954 Willys CJ3B tank   10/8/2007
Worked as advertised. Was simple and easy. Great Product.
Reviewed by: Tim S from Chicago.
99 yamaha r6 carbon fiber tank   10/7/2007
product worked amazingly and was set in about 3 days. i am going to use this for all future tank needs.
Reviewed by: keith b from San Diego, CA.
Antique oil lamps......   8/31/2007
I used this product to coat teh inside of a brass antique Parker banquet oil lamp which had stress cracks that leaked. Following the manufacturers instructions to the letter the results have been better than I had hoped for. The lamp is used as a functional showpiece now and holds kerosene and\or pure lamp oil without so much as a seep. GREAT STUFF!
Reviewed by: Mark H from Madison, WI.
got the job done   8/1/2007
effective and easy to work with.
Reviewed by: Jehshua B from Detroit, MI.
Follow the DIRECTION and DRAIN THE REMAIN   7/12/2007
I fouled my first attempt by not following the direction. Thank havens for stripper and again for good directions. The end result is truly what I had hoped for. Point.....once desired areas are coated, drain all the remainder from tank. Follow direction. Second point......KBS was very customer friendly and patient with me.
Reviewed by: jake c. from Great Falls, MT.
Small Repair Shop on Farm   7/7/2007
Worked on a tank I welded together for a reconditioned small tractor. Tank had several pinholes after assembly. Followed instructions and no leaks so far.
Reviewed by: Jim H. from Seattle, WA.
KBS Large Cycle Tank Sealer Kit   7/6/2007
It sealed a very leaky tank on a 47 Mercury coupe. The tank had lots of little pinhole holes and it sealed them from both inside and out.
Reviewed by: Carol C. from Harrisburg, PA.
Sealing 3 wheeler tank   5/26/2007
Cleaned the rusty tank with acid & rinsed well & dried well. Used the Gold Standard Tank Sealer and let dry according to directions. Worked great. No visible rust and none in filter after running machine.
Reviewed by: Glen O from Charlotte, NC.
fiberglass tank repair   5/21/2007
the product sealed the pinholes i had in 2-6.5 gallon fiberglass tanks. so far i`m tickled with the results as 2 new plastic tanks would cost $650! i recommended your product to a friend for his motorcycle tank.
Reviewed by: tom k. from Fort Wayne, IN.
Surprisingly Good!   4/5/2007
I began the project of rejuvenating a 12 gallon VW gas tank with your large motorcycle (12gal) kit with some trepidation as to the effectiveness, quality and volume of the product. Well, let me say I was very pleasantly surprised. The cleaner and De-ruster worked extremely well, (This was a 30 year old gas tank) and the sealer was astonishing! I had enough to do both the inside and complete outside of the tank. Congratulations! I was completely satisfied with this product.
Reviewed by: Bob K. from Lakeland, FL.
Received product   2/13/2007
Due to working 3 jobs and a foot and a half of snow, I have not got the chance to use it yet. After I use it I will really send in a report then. Thanks again. Fast deliverery.
Reviewed by: Richard W from Winslow, AZ.
Outstanding kit!   12/30/2006
Great products, great instructions. Thanks
Reviewed by: Stan Sk. from Santa Fe, NM.
Just the right size   12/9/2006
Product worked great!! Thanks for the "Biggie" sized kit. Fastest shipping of any website I`ve ever used.
Reviewed by: Bob J. from Eubank, KY.
Great Stuff   9/13/2006
I used this on my motorcycle tank. Work great. No longer leaks.
Reviewed by: Chris P. from Dallas, TX.
The Best   4/25/2006
I used this on my motorcycle tank and it worked perfectly. It sealed up my pinhole leak.
Reviewed by: Loved It from Houston, TX.
Excellent   4/13/2006
Amazing
Reviewed by: Ox from Adell, WI.
 Add Review KBS Large Cycle Tank Sealer Kit
Review Title:
Review:
Rating:
= Required
