Home > Restoration Kits
Average Rating
Write a Review or See Reviews
Email this page to a friend
A great 3-Step cost savings kit designed for the repair of motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
$39.00
  • The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 12 gallons.
  • Quart of AquaKlean
  • Quart of RustBlast
  • Pint of Gold Standard Tank Sealer
  • Nitrile Gloves
  • Stir Stick
  • Detailed Instructions
  • Non-flammable
  • Environmentally safe
Large Motorcycle Tank Sealer Kit   7/1/2008
I got the Large cycle tank kit. It was Enough to to do both tanks on my Honda 450 and Honda Trail 90. Did an excellent job on both tanks. I would definitely buy this product again. Thank you KBS!!
Reviewed by: Ken Berrian from Seattle, Washington.
AMAZING!!!   7/1/2008
I have a Ducati 900 SS and have had some issues with a slow leak on my tank for about a year. Tried a few other brands and always came up with the same problem.....a slow leak!.... a friend told me about KBS so I gave it a try before I spent a grand on a new tank (that I was going to do) Well KBS worked like a champ!!! Easy to use and NO LEAKS Thank You KBS
Reviewed by: Keven from AZ..
Wonderful   7/1/2008
Overall... very pleased, final job was just what I was hoping for. The cleaner and rust blaster did do their job. However, I was not satisfied so I went and did it again with my own acid materials be of my significant rust. Then I used the sealer and the final results were just fantastic.
Reviewed by: Barry Deliduka from Burlington, Vermont.
Write a Review
More Info from KBS Coatings
KBS Cycle Tank Sealer Kit
$35.00
Auto Fuel Tank Sealer Kit
$59.00
