The KBS Fuel Tank Sealer Kit contains everything you need to seal a tank of up to 5 gallons.
The tank treatment was easy to apply. It took some time do to the rust in this tank. The Tank Sealer is beginning to chaing color. But looks like it still doing its job in the tank.
Reviewed by:
M.Myers from North Carolina.
sealer was a dream
1/1/2009
I must say that the sealer was a dream. It cleaned and sealed a tank that sat for three years with a quarter tank of gas left it. This stuff is amazing. I would recommend this product to everyone!
Reviewed by:
rob v from cincinnati ohio.
Quality is excellent and easy to apply.
12/30/2008
Excellent product. 2nd time I ordered. Quality is excellent and easy to apply.
