Work Gloves
DF Clear Coat
DF Top Coat
Hi-Temp
Support & Assistance
Home > Epoxy Putty Bookmark and Share
Average Rating KBS Coatings
Reviews Write A
Review
Read Reviews on KBS Coatings Read
Reviews
Email Friend about KBS Coatings Email
Friend
KBS NuMetal :: Epoxy Putty
KBS NuMetal Epoxy Putty is a easy-to-use, two part putty you simply mix and mold like clay – no complicated weighing or measuring required. Each box contains 1 pound of putty. Select BLACK, TAN, WHITE or GREY.
**BEING USED TO FIX RECALLED TOYOTA FLOOR PEDALS**
$19.50
Color:
NuMetal Epoxy Putty is an easy-to-use, two-part putty that mixes like clay but hardens like steel! NuMetal bonds, seals, fills, insulates, anchors, caulks and waterproofs. It cures without shrinking or sagging and can be drilled, tapped, sanded, primed and painted. NuMetal will not only stick to damp surfaces, but it will cure underwater!
Our Black NuMetal is ideal for automotive applications ... if the surface coating sustains damage, the black epoxy putty beneath remains unseen! Use White NuMetal for marine applications and boat repairs. Satisfaction guaranteed!
  • Bonds to almost anything
  • Cures underwater
  • Will not shrink or sag
  • Can be applied to vertical surfaces
  • Sand, drill or carve
  • Paint, stain or gel coat
  • Withstands temps up to 300°F (150°C)
  • Easy 1:1 mix ratio
  • Cut only what you need
  • Soap & water clean up
Pool & Spa: tile & grout • PVC & ABS pipe • sealing underground pipe fittings • cracked pump housing • skimmers • pool decks • concrete decks • cracked timer & control boxes • filter grids & screens • broken control handles & knobs • patching cracks in pool gunite • concrete & plastered walls • bottoms & steps • broken pool tools • cracked coping • mounting hardware & ladders • hand rails • diving boards • water fittings • gaskets
Marine – Yacht & Boat: scrapes • dents • chips • holes • leaks • breaks on fiberglass, wood, metal & plastics • broken fuel lines • broken or cracked water lines & tanks • bonds loose carpet • waste system repairs for tanks & lines • emergency repair to engine fuel & water lines
RV & Auto: PVC & ABS pipe • water lines, fittings & tanks • broken fixtures • chipped grills • handles • emergency repair engine fuel & coolant lines • gaskets • plumbing cracks & leaks • furniture, wood, fiberglass, ceramic & plastic • tubs, toilets, sinks, tiles & caulking • emergency repairs for radiator & cracked engine blocks • battery terminals & cases
Home: furniture • water lines • PVC & ABS pipe • dents, scrapes, chips & nicks • cast iron, brick, concrete, tile, ceramics, stone, glass, pottery, wood, plastic & ceramic • sprinkling line repair • sealing underground connections & elbows • cracks & leaks in plumbing fixtures • tubs, toilets, sinks, tiles & caulking • broken filling on appliances • air conditioning & refrigeration coils • attaching golf club shafts to golf club heads
Industrial: leaking drum repair • water & air lines • HVAC coolant & refrigeration lines • plumbing fixtures
KBS NuMetal Used to Repair a Steering Wheel - Part 1
KBS NuMetal Used to Repair a Steering Wheel - Part 2 Tank Sealer - Stop Rust - Video
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings Impressed with This Putty
Am very impressed with this putty. Did everything Kbs said it would. Used it to re-build F150 door bottoms and works great !
Reviewed by: Bob A from Grand Marais, Mn . on 7/27/2010
KBS Coatings
Ratings - KBS Coatings Easy To Use
no problems,easy to apply and stays where you put it.
Reviewed by: jeff b from wausau wi. on 7/6/2010
KBS Coatings
Ratings - KBS Coatings Good Stuff
Used it to restore the steering whell in our 68 mustang,came out very good with paint you can;t tell its been repaired. Also used it to seal holes in the floor drilled by previous owner. And my try to use it to put in the floor pan
Reviewed by: Doug H from Knoxville, Tennessee. on 5/28/2010
KBS Coatings
Ratings - KBS Coatings great stuff !!!
very easy to work with! fast shipping of product.
Reviewed by: tom c. from pa. on 5/27/2010
KBS Coatings
Ratings - KBS Coatings Easy to work with and very strong
great service, epoxy putty worked great very strong easy to work with and very strong
Reviewed by: Ruben A from San Jose, CA. on 5/27/2010
KBS Coatings
Ratings - KBS Coatings Superior Product!
Even an untrained person in a matter of minutes will be capable of making smooth repairs using KBS epoxy. You only have to show them one time how easy it is to use and they are basically trained.Superior product.
Reviewed by: Neil R from Nashville , TN. on 4/27/2010
KBS Coatings
Ratings - KBS Coatings Love it, but
I have used the Numetal on many items, from my truck restorations to the grass trimmer, and always found it to be fantastic. Loved it so much order two pounds this last time. One major complaint though,is that this order arrived so dried out and crunchy most went to waste, as it was not malleable at all.
Reviewed by: Jim from Ft. Lauderdale. on 3/9/2010
KBS Coatings
Ratings - KBS Coatings TRACTOR TANK
WORKS GREAT NO PROBLEM WITH THIS PRODUCT,PLEASED--THANKS,GARY
Reviewed by: GARY A from LONGVIEW TEXAS. on 12/28/2009
KBS Coatings
Ratings - KBS Coatings Works Great
Used this a couple of times now, my primary reason was to patch a couple of holes in an old motorcycle fender. I had soda blasted the fender and the blasting knocked out two old rust holes. After filling, sanding and painting you can't even see where the holes were, and I couldn't tell you without looking at the backside. I love this stuff.
Reviewed by: Donald C from LaGrange, KY. on 11/30/2009
KBS Coatings
Ratings - KBS Coatings KBS NuMetal Expoxy Putty a product that actually delivers on its claims
I ordered and used this KBS putty to fill and fix a large expansion crack on a marine steering wheel after learning that a new wheel would cost me >200 dollars. Well, 3-4 hours of work later, I am extremely pleased with the results. The epoxy did not swell or shrink at all throughout the process. The repair is now 6 weeks old and looks very good (not noticeable by other people). The epoxy is easy to sand and can be planned with a very sharp razor. Quality product, very pleased.
Reviewed by: Grant J. from Bloomington, IN. on 8/30/2009
KBS Coatings
Ratings - KBS Coatings Patched Holes
I had several small holes in the bottom of my motorcycle tank and used NuMetal to patch them. Product works great.
Reviewed by: mark j from grand rapids, mi. on 7/2/2009
KBS Coatings
Ratings - KBS Coatings Good product
I bought it to fix a leaky pipe. I used it on a copper pipe under my kitchen sink. Has been 60 days and no more leak. Worked great. I plan to use the rest to fix a hole in my exhaust on my lexus rather than buy a new exhaust
Reviewed by: darrell from Virginia. on 1/30/2009
KBS Coatings
Ratings - KBS Coatings Steering Wheel
I recently repaired my 68 cougar steering wheel and it looks great. This product is easy to use and final product looks like new.
Reviewed by: Ron L from Mary Esther, FL. on 12/31/2008
KBS Coatings
Ratings - KBS Coatings 1953 Chrysler steering wheel
Used this to restore a 1953 Chrysler steering wheel. It was in bad shape with multiple cracks and separations. The putty restored to to like new condition. I''m putting the wheel on an old Chris Craft.
Reviewed by: Don C from Gadsden, Alabama. on 12/30/2008
KBS Coatings
Ratings - KBS Coatings Great Repair to Saxophone Mouthpieces
Finally got around to use the KBS Black Epoxy Putty to repair a few of my vintage sax mouthpieces because of wear. It worked better than I expected...GREAT PRODUCT!!!
Reviewed by: Thom A. from Alex, Oklahoma. on 11/21/2008
KBS Coatings
Ratings - KBS Coatings Super stuff!
Super stuff! Used it to mend two 1cm rust holes in my cycle tank. Easy to mix, mold, sand and paint. Also using to mend smaller rust holes on my car - much easier and less messy than Bondo!
Reviewed by: Claudia F from Syracuse, NY. on 10/1/2008
KBS Coatings
Ratings - KBS Coatings FANTASTIC Product
Being my first time doing any type of body work, this was on a motorcycle, your product was fantastic. It was not had easy to follow instructions but it also bended well, hardend quickly to a rock hard base. I even used it to patch a hole in the gas tank. I would highly recommend this to everyone.
Reviewed by: Susan M from Hop Bottom, PA. on 9/9/2008
KBS Coatings
Ratings - KBS Coatings Great for Firearms/synthetic stocks
I used it to repair a cracked black-synthetic rifle stock, and found it is an EXACT color match and is invisible once dry. Easy to use, can be surface finished with a fingertip and water, and easy to clean up. I rolled out a scrap piece between a piece of wax paper so it was semi-flat. Later that night after it cured, I tried to snap the piece in half which was very hard to do. I eventually did, but this stuff is STRONG!
Reviewed by: Troy from People's Republik of NJ. on 8/29/2008
KBS Coatings
Ratings - KBS Coatings What a Great Product
Even as a novice auto body repair person this was a piece of cake. It worked exactly as described. The previous bondo attempt on a rusted area on my car was no match for the repair that nu-metal gave me. I highly recommend it.
Reviewed by: Theresa from Arizona. on 6/16/2008
KBS Coatings
Ratings - KBS Coatings Worked better than expected
The putty was easy to use it was also easy to mix,it had all the properties I needed and I found it easy to apply to other uses,I also found it is easy to sand and can be drilled and tapped if need be .Clean up was a snap and it seems to be a cure for alot of underwater applications ,as a working diver and mechanic I highly recommend this product!!
Reviewed by: Danny T. from old bridge N.J.. on 5/2/2008
KBS Coatings
Ratings - KBS Coatings Ground Support Manager Scottsdale Airport
This is fantastic stuff, the best I have used.
Reviewed by: E Miller from Scottsdale Arizona. on 2/7/2008
KBS Coatings
Ratings - KBS Coatings Works great
Works great: Bonds strong, easy cleanup, sets up hard as a rock. Perfect!
Reviewed by: Joe from Pasco, WA. on 2/2/2008
KBS Coatings
Ratings - KBS Coatings Excellent Product
an excellent product and good service
Reviewed by: Myron F. from California. on 2/2/2008
KBS Coatings
Ratings - KBS Coatings Great for shaping over welds
Easy to work with as far as shaping and adhesion. Dries super hard and can be sanded down to a smooth finish.
Reviewed by: Herminio M. from San Francisco, CA. on 2/1/2008
KBS Coatings
Ratings - KBS Coatings Hard As A Rock!
Great Product, worked as advertised! Hard as a rock.
Reviewed by: Bill S from Dublin, OH. on 10/8/2007
KBS Coatings
Ratings - KBS Coatings GREAT STUFF!
Seems expensive, until you see how much a pound is. I`ve used it three times and still have 3/4 of it left. Easy to mix; easy to shape; easy to sand. It`s great. I didn`t use gloves and it didn`t stick to my hands; the slight residue washed off easily with soap and water.
Reviewed by: Charles S from Billings, MT. on 9/1/2007
KBS Coatings
Ratings - KBS Coatings kbs is tops
quick service, great product, will use again
Reviewed by: mike r from Kearney, NE. on 8/31/2007
KBS Coatings
Ratings - KBS Coatings Easy To Work With
This product is great! It was easy to work with when you follow the directions. It dried solid and smooth. I used it to repair some rusted out holes in a steel floor pan.
Reviewed by: Amy, R from Huron, SD. on 8/8/2007
KBS Coatings
Ratings - KBS Coatings Great repairs to plastic and steel
This stuff worked great for my hard saddle bag and center stand repairs to my BMW motorcycle.
Reviewed by: Jim B. from Casper, WY. on 7/14/2007
KBS Coatings
Ratings - KBS Coatings Patched Steering Wheel
I recently used this on a cracked steering wheel. It was easy to use and work with. This product gets very hard and sands good too.
Reviewed by: Brooks A. from Great Falls, MT. on 7/6/2007
KBS Coatings
Ratings - KBS Coatings Repair Worked Great!
Fast shipping, Repaired the fiberglass hull of my Waverunner. The repair worked great, sanded easily and painted well.Color matches my hull so scratches won`t show through.
Reviewed by: Dave, R from Memphis, TN. on 7/6/2007
KBS Coatings
Ratings - KBS Coatings Worked Exceptional!
Good Info. Exceptional timely shipping. Product worked exceptional!
Reviewed by: Dave M. from Lakeland, FL. on 3/1/2007
KBS Coatings
Ratings - KBS Coatings Great Stuff and Easy to Work With
Used to fill a couple of rust throughs in a fuel tank before sealing...great stuff and easy to work with. Will be very useful in pending full restoration project.
Reviewed by: Bruce M from Spokane, WA. on 1/5/2007
KBS Coatings
Ratings - KBS Coatings Great stuff
I repaired a severely cracked fibreglass shower enclosure with this stuff and it worked great and made the repair invisible. It`s easy to use too much as I found out it went a long way which made for alot of sanding. Howevere it is an excellent product. Tip-let the package sit in the sun for a few minutes which will make it easier to "work".
Reviewed by: Peter W. from Portland, OR. on 10/6/2006
KBS Coatings
Ratings - KBS Coatings great on exhaust
I had a leak in my exhaust system. This stuff patched it up great.
Reviewed by: HandyMan from Stockton, CA. on 9/13/2006
KBS Coatings
Ratings - KBS Coatings Super Putty!!!!
I had my doubts about this stuff, but used some on a rotted out drip rail. It blended easy, smoothed out nice, and sanded well. Took paint great too! Great stuff!!!
Reviewed by: Neal F. from Eubank, KY. on 5/12/2006
KBS Coatings
See All Reviews
Paint For Rust
Paint For Rust
$110.00
Paint For Rust
KBS BackBone Reinforcing Mesh
$7.00
