Home > Epoxy Putty
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS NuMetal :: Epoxy Putty
KBS NuMetal Epoxy Putty is a easy-to-use, two part putty you simply mix and mold like clay – no complicated weighing or measuring required. Available in one pound box in BLACK, TAN, & WHITE!
$19.50
Color:
NuMetal Epoxy Putty is an easy-to-use, two-part putty that mixes like clay but hardens like steel! NuMetal bonds, seals, fills, insulates, anchors, caulks and waterproofs. It cures without shrinking or sagging and can be drilled, tapped, sanded, primed and painted. NuMetal will not only stick to damp surfaces, but it will cure underwater!
Our Black NuMetal is ideal for automotive applications…if the surface coating sustains damage, the black epoxy putty beneath remains unseen! Use White NuMetal for marine applications and boat repairs. Satisfaction guaranteed!
  • Bonds to almost anything
  • Cures underwater
  • Won’t shrink or sag
  • Can be applied to vertical surfaces
  • Sand, drill or carve
  • Paint, stain or gel coat
  • Withstands temps up to 300°F (150°C)
  • Easy 1:1 mix ratio
  • Cut only what you need
  • Soap & water clean up
all metals • wood • ceramic • porcelain PVC • ABS Pipe • brick • stone • leaky gas tanks • broken fuel lines • steering wheels • plastic parts/knobs • manifolds cracked fiberglass • marine repairs • pool repairs • insulate • repair holes in decks or tiles • use like modeling clay • carvings • concrete • plaster • tile • grout • tool handles
What a Great Product   6/16/2008
Even as a novice auto body repair person this was a piece of cake. It worked exactly as described. The previous bondo attempt on a rusted area on my car was no match for the repair that nu-metal gave me. I highly recommend it.
Reviewed by: Theresa from Arizona.
Worked better than expected   5/2/2008
The putty was easy to use it was also easy to mix,it had all the properties I needed and I found it easy to apply to other uses,I also found it is easy to sand and can be drilled and tapped if need be .Clean up was a snap and it seems to be a cure for alot of underwater applications ,as a working diver and mechanic I highly recommend this product!!
Reviewed by: Danny T. from old bridge N.J..
Ground Support Manager Scottsdale Airport   2/7/2008
This is fantastic stuff, the best I have used.
Reviewed by: E Miller from Scottsdale Arizona.
Works great   2/2/2008
Works great: Bonds strong, easy cleanup, sets up hard as a rock. Perfect!
Reviewed by: Joe from Pasco, WA.
self   2/2/2008
an excellent product and good service
Reviewed by: Myron F. from California.
Great for shaping over welds   2/1/2008
Easy to work with as far as shaping and adhesion. Dries super hard and can be sanded down to a smooth finish.
Reviewed by: Herminio M. from San Francisco, CA.
Numetal Epoxy   10/8/2007
Great Product, worked as advertised! Hard as a rock.
Reviewed by: Bill S from Dublin, OH.
GREAT STUFF!   9/1/2007
Seems expensive, until you see how much a pound is. I`ve used it three times and still have 3/4 of it left. Easy to mix; easy to shape; easy to sand. It`s great. I didn`t use gloves and it didn`t stick to my hands; the slight residue washed off easily with soap and water.
Reviewed by: Charles S from Billings, MT.
kbs is tops   8/31/2007
quick service, great product, will use again
Reviewed by: mike r from Kearney, NE.
New Metal Epoxy   8/8/2007
This product is great! It was easy to work with when you follow the directions. It dried solid and smooth. I used it to repair some rusted out holes in a steel floor pan.
Reviewed by: Amy, R from Huron, SD.
Great repairs to plastic and steel   7/14/2007
This stuff worked great for my hard saddle bag and center stand repairs to my BMW motorcycle.
Reviewed by: Jim B. from Casper, WY.
Patched Steering Wheel   7/6/2007
I recently used this on a cracked steering wheel. It was easy to use and work with. This product gets very hard and sands good too.
Reviewed by: Brooks A. from Great Falls, MT.
Epoxy putty   7/6/2007
Fast shipping, Repaired the fiberglass hull of my Waverunner. The repair worked great, sanded easily and painted well.Color matches my hull so scratches won`t show through.
Reviewed by: Dave, R from Memphis, TN.
Nu Metal Review   3/1/2007
Good Info Exceptional timely shipping Product worked exceptional
Reviewed by: Dave M. from Lakeland, FL.
NuMetal Epoxy   1/5/2007
Used to fill a couple of rust throughs in a fuel tank before sealing...great stuff and easy to work with. Will be very useful in pending full restoration project.
Reviewed by: Bruce M from Spokane, WA.
Great stuff   10/6/2006
I repaired a severely cracked fibreglass shower enclosure with this stuff and it worked great and made the repair invisible. It`s easy to use too much as I found out it went a long way which made for alot of sanding. Howevere it is an excellent product. Tip-let the package sit in the sun for a few minutes which will make it easier to "work".
Reviewed by: Peter W. from Portland, OR.
great on exhaust   9/13/2006
I had a leak in my exhaust system. This stuff patched it up great.
Reviewed by: HandyMan from Stockton, CA.
Super Putty!!!!   5/12/2006
I had my doubts about this stuff, but used some on a rotted out drip rail. It blended easy, smoothed out nice, and sanded well. Took paint great too! Great stuff!!!
Reviewed by: Neal F. from Eubank, KY.
 Add Review KBS NuMetal :: Epoxy Putty
Review Title:
Review:
Rating:
= Required
