Home > Epoxy Putty
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS NuMetal :: Epoxy Putty
KBS NuMetal Epoxy Putty is a easy-to-use, two part putty you simply mix and mold like clay – no complicated weighing or measuring required. Available in one pound box in BLACK, TAN, & WHITE!
$19.50
Color:
Overview
  • KBS NuMetal Epoxy Putty is an easy-to-use, two-part putty that professionals have come to rely on. It is manufactured with the highest quality materials and formulated for the solid repair of products used in the home, plant, pool, spa, auto, RV, boat, marine and plumbing markets.
  • NuMetal is water-based so it mixes easily like clay but hardens like steel. In a simple 1:1 "cut what you need mix ratio" application, NuMetal will bond to almost anything. Just use your imagination, our NuMetal bonds, seals, fills, anchors, caulks and waterproofs.
  • Once cured, NuMetal can be drilled, tapped, sanded, and painted.
  • It cures without shrinking or sagging and can be sanded, primed and painted. Incredibly, it even sticks to damp surfaces and will CURE UNDERWATER.
  • NuMetal is resistant to heat, cold, most fuels, and most common chemicals, solvents and caustic agents.
Next »
Features
  • Cures underwater
  • Won't Shrink or Sag
  • Sand, drill, or carve
  • Paint, stain or gel coat
  • 1:1 Mix Ratio
  • Soap and water cleanup
  • Easy 1:1 "Cut what you need mix ratio"
Next »
Surfaces
NUMETAL BONDS TO ALMOST ANYTHING INCLUDING:
  • all metals
  • copper
  • iron
  • chrome
  • fiberglass
  • wood
  • concrete plaster
  • ceramic
  • porcelain
  • pottery
  • plastics
  • PVC pipe
  • ABS pipe
  • brick
  • stone
  • glass
  • tile
  • grout
Next »
Applications
  • cracked metals
  • leaky gas tanks
  • broken fuel lines
  • steering wheels
  • plastic parts/knobs
  • headers
  • manifolds
  • bond loose carpet insulate
  • spliced cable
  • repair holes in decks or tiles
  • sculpting, modeling and carving
  • furniture repair
  • leaky plumbing fixtures
  • patch concrete
Next »
Info Pages
Worked better than expected   5/2/2008
The putty was easy to use it was also easy to mix,it had all the properties I needed and I found it easy to apply to other uses,I also found it is easy to sand and can be drilled and tapped if need be .Clean up was a snap and it seems to be a cure for alot of underwater applications ,as a working diver and mechanic I highly recommend this product!!
Reviewed by: Danny Townley from old bridge N.J..
Ground Support Manager Scottsdale Airport   2/7/2008
This is fantastic stuff, the best I have used.
Reviewed by: E Miller from Scottsdale Arizona.
Works great   2/2/2008
Works great: Bonds strong, easy cleanup, sets up hard as a rock. Perfect!
Reviewed by: Joe from Pasco, WA.
Write a Review
More Info from KBS Coatings
$110.00
KBS BackBone :: Reinforcing Mesh
$7.00
