Home > Prep Products
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS RustBlast
KBS RustBlast
KBS RustBlast is a powerful rust remover and zinc phosphate pre-primer & metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides, and tarnishing from most metal surfaces, while providing extended protection against flash-rusting thanks to KBS' unique Oxygen-Block technology.
8oz. - $6.50
Quart - $14.50
Gallon - $28.00
5 Gallon - $130.00
$0.00
Size:
Easy-to-use spray or brush application. Apply RustBlast full strength to a clean surface keeping it wet for 20-30 minutes or more and watch rust, corrosion, metal oxides, and tarnishing vanish before your eyes!
RustBlast will gently etch the surface and leave a zinc phosphate coating to ensure a strong bond with any paint.
Satisfaction guaranteed!
  • Removes & neutralizes rust
  • Pre-paint primer
  • Provides etched surface profile for solid adhesion
  • Leaves a zinc phosphate base coating
  • Oxygen-Block enhanced for short term corrosion protection
  • Enhances welding conductivity
  • Non-flammable, no petroleum additives
  • Non-corrosive
  • Water-based, biodegradable
  • steel
  • cast iron
  • brass
  • aluminum
  • galvanized
  • copper
  • steel alloys
  • fiberglass
  • other non-metallic surface
  • concrete
  • rust removal
  • metal etching
  • mill scale removal
  • pre-paint surface treatment
  • 1 Gallon of RustBlast for each Gallon of KBS RustSeal
  • Gallon comes with Sprayer and Bottle
  • 1 Quart of RustBlast for each Quart of KBS RustSeal
  • Quart Comes with Sprayer
  • 1 - 8oz. of RustBlast for each 8oz. of KBS RustSeal
  • Click HERE to see how Howie used RustBlast to prep and etch a Ford Flat Head.
  • Click HERE to see how Howie used RustBlast to prep and etch some posts and the welds.
  • Click HERE to see how Howie used RustBlast to prep and etch a gas tank.
maintenance   2/3/2008
I just used rust blast. I had a metal screen that had a lot of rust on it so I used a wire brush and removed most of it. I then used rust blast and kept it on for twenty minutes and washed it off. I left it overnight and usually, next to the beach the screen would rust. I think this is an excellent product and will enhance the use of rust seal.
Reviewed by: Danny from Holmes Beach, Florida.
good stuff!   9/6/2007
prompt service, good product, Thanks!
Reviewed by: Dave H. from San Diego, TX.
Rust Blast   7/5/2007
It is the best I`ve used. So easy my wife took over and couldn`t have done better myself!!!!!! Thanks for a great product!!
Reviewed by: Adrian S. from Durant, OK.
Miracles Do Happen!   7/5/2007
I purchased the KBS Motorcyle Tank Sealer Kit to repair a very rusty motorcycle tank. It had been collecting rust for over 10 years. Ultimately, my tank was free of rust and it is now sealed so that no more rust can happen again. It really worked!
Reviewed by: Kent N. from Vernal, UT.
RustBlast   3/1/2007
Removed rust from 1970`s era motorcycle fuel tank. Would use again
Reviewed by: Greg M. from Merced, CA.
WOW!   12/6/2006
Product works exactly as described. Within minutes a noticable change takes place, especially on the lightly rusted spots. Kept the rust away for 7 days exposed to the damp/humid Houston weather.
Reviewed by: Tony R. from Hood River, WA.
Seems to work very well   12/6/2006
I may not be totally able to tell what this stuff does as far as the etching goes, but the rust "blasting" aspect is really noticeable.
Reviewed by: Gary M from Denton, MT.
Rustblast review   4/30/2006
worked as stated. removed rust stains from our curbs & sidewalks. Good stuff.
Reviewed by: Tom H. from Cortez, CO.
 Add Review KBS RustBlast
Review Title:
Review:
Rating:
= Required
