Home > Prep Products
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS RustBlast
KBS RustBlast
KBS RustBlast is a powerful rust remover and zinc phosphate pre-primer & metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides, and tarnishing from most metal surfaces, while providing extended protection against flash-rusting thanks to KBS' unique Oxygen-Block technology.
8oz. - $6.50
Quart - $14.50
Gallon - $28.00
5 Gallon - $130.00
$0.00
Size:
Easy-to-use spray or brush application. Apply RustBlast full strength to a clean surface keeping it wet for 20-30 minutes or more and watch rust, corrosion, metal oxides, and tarnishing vanish before your eyes!
RustBlast will gently etch the surface and leave a zinc phosphate coating to ensure a strong bond with any paint.
Satisfaction guaranteed!
  • Removes & neutralizes rust
  • Pre-paint primer
  • Provides etched surface profile for solid adhesion
  • Leaves a zinc phosphate base coating
  • Oxygen-Block enhanced for short term corrosion protection
  • Enhances welding conductivity
  • Non-flammable, no petroleum additives
  • Non-corrosive
  • Water-based, biodegradable
  • steel
  • cast iron
  • brass
  • aluminum
  • galvanized
  • copper
  • steel alloys
  • fiberglass
  • other non-metallic surface
  • concrete
  • rust removal
  • metal etching
  • mill scale removal
  • pre-paint surface treatment
  • 1 Gallon of RustBlast for each Gallon of KBS RustSeal
  • Gallon comes with Sprayer and Bottle
  • 1 Quart of RustBlast for each Quart of KBS RustSeal
  • Quart Comes with Sprayer
  • 1 - 8oz. of RustBlast for each 8oz. of KBS RustSeal
  • Click HERE to see how Howie used RustBlast to prep and etch a Ford Flat Head.
  • Click HERE to see how Howie used RustBlast to prep and etch some posts and the welds.
  • Click HERE to see how Howie used RustBlast to prep and etch a gas tank.
maintenance   2/3/2008
I just used rust blast. I had a metal screen that had a lot of rust on it so I used a wire brush and removed most of it. I then used rust blast and kept it on for twenty minutes and washed it off. I left it overnight and usually, next to the beach the screen would rust. I think this is an excellent product and will enhance the use of rust seal.
Reviewed by: Danny from Holmes Beach, Florida.
good stuff!   9/6/2007
prompt service, good product, Thanks!
Reviewed by: Dave H. from San Diego, TX.
Rust Blast   7/5/2007
It is the best I`ve used. So easy my wife took over and couldn`t have done better myself!!!!!! Thanks for a great product!!
Reviewed by: Adrian S. from Durant, OK.
Write a Review
KBS AquaKlean
More Info from KBS Coatings
KBS Frame Coater Kit
$55.00
