High Temperature Paint
Home > Rust Sealer Bookmark and Share
Average Rating KBS Coatings
KBS RustSeal is a superior one part, ready-to-use, high-solid content, rust preventive coating, that is actually strengthened by exposure to moisture. It is impervious to road salts and most every chemical. RustSeal flows out to a beautiful, rock-hard, tough coating that is tough to chip or scratch.
8oz. - $14.50  |  Pint - $24.00  |  Quart - $36.00
Gallon - $110.00  |  5 Gallon - $490.00
$0.00
Size:
Color:
Gloss
Black
Satin
Black
Off-White
Clear
Grey
Silver
Oxide
Red
Guardian
Green
Galvanized
Steel
*Click HERE for the unique characteristics of Galvanized Steel and to order.
RustSeal - Stop Rust - Like POR-15
RustSeal is an incredible, single-component, ready-to-use, high solids content, rust preventive coating with exceptional sealing properties.
No other brand is tougher on rust! Using premium quality materials & advanced color formulations, this high tech performance coating is the present-day answer for 21st century rust protection.
RustSeal is the most permanent cost-effective solution for stopping rust & corrosion anyplace where it is a problem: home, automotive, industry, fleet, farm & more!
It’s technology that’s unbeatable! Satisfaction guaranteed!
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • 8 oz. of RustSeal will cover 12.5 sq. ft. with two coats.
  • A Pint of RustSeal will cover 25 sq. ft. with two coats.
  • A Quart of RustSeal will cover 50 sq. ft. with two coats.
  • A Gallon of RustSeal will cover 200 sq. ft. with two coats.
  • A 5 Gallon Pail of RustSeal will cover 1000 sq. ft. with two coats.
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings Excellent product
1.) As promised, I couldn't find a solvent that could attack it after curing. 2.) Flow-out and self-leveling properties are amazing and like nothing I've ever seen. 3.) Cured hardness is similar to a good two-part epoxy primer. 4.) Make sure to clean can lid groove after use, or you might not get lid off again. 5.) Flow-out is so good that the flip-side problem can surface where the paint flows away from edges or high points. These small areas will probably require a second touch-up.
Reviewed by: Mark, P. from Yuma, AZ. on 3/9/2010
KBS Coatings
Ratings - KBS Coatings Worked Great
Love the product. I used allot of cheap 2" brown wood handle bristle brushes from Wal-Mart. The foam brushes don't hold-up on the ruff chassis work and getting into the little nooks and crannies. Don't bother washing them. For 50 cents just toss them in the trash. Poke a hole and the can and use a piece of duct tape to seal the hole. Makes it easy to pour out a little at a time for use and it will keep the can from hardening. Oh! If you are working under the car wear long sleeves. LOL
Reviewed by: Joe M from Cooperstown, NY. on 11/25/2009
KBS Coatings
Ratings - KBS Coatings Exceptional
Your service was exceptional, I ordered one day and it was literally there the next day. The product went on well and I hope it prevents the rust on my trailer.
Reviewed by: Arden M from Fremont, MIchigan. on 10/28/2009
KBS Coatings
Ratings - KBS Coatings Great product
Great product. Worked just as described. Shipping was also great. Arrived before expected.
Reviewed by: Ralph I. from Cosmos, Mn.. on 9/30/2009
KBS Coatings
Ratings - KBS Coatings Hard as a rock
I am in the process of frame up resto on my 54 Ford. This stuff is hard as a rock and also gives the vehicle that brand new look. It's nice to have a product that will protect and always look good when showing the car. Thanks
Reviewed by: Dennis V from Mid Michigan. on 9/5/2009
KBS Coatings
See All Reviews
Paint For Rust
KBS RustSeal - Galvanized Steel
Paint For Rust
Paint For Rust
KBS Frame Coater Kit
$55.00
