Average Rating |
Back to Main |
7/1/2008 |
| Great product, goes on easily, looks great. |
| Reviewed by: |
felix from NJ. |
5/1/2008 |
| I bought 2 quarts of the black over at a VW show. I got a ''70 Westy, discovered some rust iin the back floor. Figured this would be perfect. Prepped everything by using a wire wheel on rust, sanded painted surfaces. Loved the way it turned out and how durable it was I wound up painting the metal seat backs in the front white along with the front floor black! I do wish the white was thinner, but then again it would require more coats on a dark surface. Thanks KBS! WORKS GREAT! |
| Reviewed by: |
Tony C from McHenry, IL. |
5/1/2008 |
| Way better than POR 15 |
| Reviewed by: |
Keith A. from Tekoa Wa.. |
4/2/2008 |
| I am working on a 1967 Ford Fairlane convertible. I have worked with other paint before and nothing comes close to this Awesome finish without other chemicals.Liked the way it brushed on and the way it smoothed out like it was sprayed on. !!!!!!!!!BUY SOME NOW YOU WOULD BE VERY HAPPY!!!!!!!!!!!!!!!! |
| Reviewed by: |
Shawn H. from Aurora Indiana. |
3/4/2008 |
| Around here, my old Explorer would be toast without RustSeal. It looks great. Thanks! |
| Reviewed by: |
Donna F. from Lincoln City OR. |
3/4/2008 |
| Made my accent pieces look awesome. |
| Reviewed by: |
Erik from Maryland. |
3/4/2008 |
| Made the frame looks like it can withstand a bomb blast, we will see ... hahaha |
| Reviewed by: |
3/4/2008 |
| I bought the RustSeal to use on wood and concrete. The wood was framing 2X4''s which tended to become damp and grow mildew. I applied one coat of Rust Seal which the wood soaked up. No more mildew. The rest was applied as a test patch on the concrete on the utility room floor. This was applied over old "concrete paint" without the use of a primer. Its been two months and it appears to have adhered perfectly. When Spring comes I plan to do the entire floor. |
| Reviewed by: |
Lee Estes from Milford, MI. |
2/13/2008 |
| I have used the Rust Seal coating and the epoxy putty with great results from both. I have found the consistency of the Rust seal better than the POR I have been using for over 10 years. Your product flows and covers better, seems to be a higher solids coating.
| Reviewed by: |
Mike M from NY. |
2/4/2008 |
| I absolutely love this stuff! I am on my second order and for frames and sheet metal items this stuff is the greatest. It has made several hard to finish areas on my truck look like new. I will be ordering again! |
| Reviewed by: |
Brad A. from Salt Lake City, UT. |
2/4/2008 |
| Product works great, excellent adhesion. Looks and works great. |
| Reviewed by: |
Tom G. from Bonifay, FL. |
2/1/2008 |
| Husband is restoring a old classic car. Says that this product is the best he has ever used on frames. Great service. Thanks |
| Reviewed by: |
Barbara G. from Abbeville, LA. |
11/1/2007 |
| This is great stuff, works best on bare rusty metal sticks like nothing else and protects like it claims. |
| Reviewed by: |
John B from Valdosta, GA. |
10/11/2007 |
| Flows out well,no need for spray, Flows out like glass. Unbelivably tough |
| Reviewed by: |
Charlie T from St. Augustine, FL. |
10/9/2007 |
| Looks Great! |
| Reviewed by: |
Chris P. from Florence, SC. |
10/8/2007 |
| Excellent wet wet wet then totally dry hard as a rock |
| Reviewed by: |
rick c. from Woodbury, TN. |
7/7/2007 |
| As a restorer, it is easy to use, more effective than POR and Customer support is a million times better than POR ever thought of. BELIEVE ME. been there. Good product, Ray |
| Reviewed by: |
Stripmasters Inc from Eubank, KY. |
3/1/2007 |
| Man this is some good stuff sticks to everything. I feel comfortable using it and know it covered the rust. |
| Reviewed by: |
Lance K. from Portland, OR. |
1/5/2007 |
| I am well pleased with the KBS in our restoration shop. The product is easer to apply than POR 15 and has a better appearing finish. Although it is still nasty stuff to undercoat by hand, my guys much prefer it over competitors products. |
| Reviewed by: |
Gary F. from San Diego, CA. |
12/12/2006 |
| this paint is what it says it is don`t crack,chip,scratch try it you`ll like it |
| Reviewed by: |
Johnny H from Madison, WI. |
12/7/2006 |
| I have a 68 mustang with some bad rust.NOT ANYMORE!!! very easy you just have to make sure you do good prep work. |
| Reviewed by: |
Jermiah from Detroit, MI. |
12/6/2006 |
| Laid it on with a brush, per instructions, and was very concerned at all the brush strokes. Just minutes later I was amazed at how the finnish turned into a high-gloss finished laquer looking finish! A quart put two coats, top and bottom, of a 5` brush hog, including all the support members. |
| Reviewed by: |
Tony R. from Charlotte, NC. |
12/6/2006 |
| Although I have not used this product yet, I have used the POR-15 products and if this stuff is anywhere better than POR-15, it`s gonna rock! |
| Reviewed by: |
Gary M from Houston, TX. |
12/1/2006 |
| Used por for years, but this paint is more user-friendly and I really like the finish. I`ll be buying more.
Thanks |
| Reviewed by: |
Sam U. from Morristown, NJ. |
11/16/2006 |
| I bought some before it worked Awesome. the shipping was AAA+++ |
| Reviewed by: |
Sam Z. from Dallas, TX. |
11/6/2006 |
| This is some amazing stuff. Does what they say. Excellent |
| Reviewed by: |
Brian R. from Houston, TX. |
10/28/2006 |
| Put the por15 away and go with KBS today! I`m telling all my buddies about rustseal. |
| Reviewed by: |
karl k from Adell, WI. |
10/24/2006 |
| I AM INTERESTED IN SELLING YOUR PRODUCTS. I HAVE USED YOUR PRODUCT FOR THE SECOND TIME AND I FIND IT TO BE MORE USER FRIENDLY THEN POR 15. TERE IS ALOT LESS WAIT TIME BETWEEN APPLICATION OF YOUR PRODUCT AND TOP COAT. THAT HELPS ME OUT TREMENDOUSLY. Thank you |
| Reviewed by: |
Aladdin D. from Ashley, MI. |
10/6/2006 |
| Love the satin finish! Dries super hard and smooth. Was a big POr user, but this stuff rocks, plus the price, plus the service and tech support (talked with a live person after 8pm est). Save your $$ go the KBS way!! Thanks guys |
| Reviewed by: |
Stan V. from Ord, NE. |
9/25/2006 |
| Prompt postage, simple to order from your website, product was was easy to use and the instructions were clear. Used on kids pushbikes and will be ordering more for the swing-set! |
| Reviewed by: |
Cath B from Charlotte, NC. |
9/19/2006 |
| I used this stuff to seal up the bottom of my fishing boat and it worked great. No more leaks and it withstands me running into rocks and such. |
| Reviewed by: |
Jeff P. from Utica, OH. |
9/17/2006 |
| Great products Also appreciate the after hours tech support. I`ll be sure to spread the word. |
| Reviewed by: |
John John from Winter Haven, FL. |
6/30/2006 |
| This stuff is incredible. I was a little skepical and it is kind of expensive compared to paints that I usually purchase. This stuff made me a believer. |
| Reviewed by: |
Randy K from Martinsville, VA. |
6/13/2006 |
| I love this products.
And I`m happy to buy this one from this site.
Thanks. |
| Reviewed by: |
Seunghwan C. from Santa Fe, NM. |
6/6/2006 |
| Seems as good as Chassis saver and better than POR-15. Need a satin black, but i hear that`s coming soon. Keep up the quick service too! |
| Reviewed by: |
Stevie P from Daytona Beach, FL. |
5/19/2006 |
| This stuff laid out just like powder coating. I was stunned. I have no idea how well it will hold up because I just put it on, but it looks awesome. |
| Reviewed by: |
Howard Y. from Cincy, OH. |
5/14/2006 |
| My kids have a swingset that looked terrible from all of the rust. I use this and then put a topcoat on it. It looks great. |
| Reviewed by: |
Chris W from Pickens, WV. |
