Home > Rust Sealer
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS RustSeal is a superior one part, ready-to-use, high-solid content, rust preventive coating, that is actually strengthened by exposure to moisture. It is impervious to road salts and most every chemical. RustSeal flows out to a beautiful, rock-hard, tough coating that is tough to chip or scratch.
8oz. - $14.50
Pint - $24.00
Quart - $36.00
Gallon - $110.00
5 Gallon - $490.00
$0.00
Size:
Color:
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
KBS RustSeal - Stop Rust
RustSeal is an incredible, single-component, ready-to-use, high solids content, rust preventive coating with exceptional sealing properties. No other brand is tougher on rust! Using premium quality materials & advanced color formulations, this high tech performance coating is the present-day answer for 21st century rust protection.
RustSeal is the most permanent cost-effective solution for stopping rust & corrosion anyplace where it is a problem: home, automotive, industry, fleet, farm & more! It’s technology that’s unbeatable! Satisfaction guaranteed!
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • 8 oz. of RustSeal will cover 12.5 sq. ft. with two coats.
  • A Pint of RustSeal will cover 25 sq. ft. with two coats.
  • A Quart of RustSeal will cover 50 sq. ft. with two coats.
  • A Gallon of RustSeal will cover 200 sq. ft. with two coats.
  • A 5 Gallon Pail of RustSeal will cover 1000 sq. ft. with two coats.
Did everything it was supposed to do   5/1/2008
Way better than POR 15
Reviewed by: Keith A. from Tekoa Wa..
This stuff works great!!   5/1/2008
I bought 2 quarts of the black over at a VW show. I got a ''70 Westy, discovered some rust iin the back floor. Figured this would be perfect. Prepped everything by using a wire wheel on rust, sanded painted surfaces. Loved the way it turned out and how durable it was I wound up painting the metal seat backs in the front white along with the front floor black! I do wish the white was thinner, but then again it would require more coats on a dark surface. Thanks KBS! WORKS GREAT!
Reviewed by: Tony C from McHenry, IL.
best paint ever used   4/2/2008
I am working on a 1967 Ford Fairlane convertible. I have worked with other paint before and nothing comes close to this Awesome finish without other chemicals.Liked the way it brushed on and the way it smoothed out like it was sprayed on. !!!!!!!!!BUY SOME NOW YOU WOULD BE VERY HAPPY!!!!!!!!!!!!!!!!
Reviewed by: Shawn H. from Aurora Indiana.
Write a Review
More Info from KBS Coatings
KBS Frame Coater Kit
$55.00
$110.00
