Home > Rust Sealer
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS System Sampler Kit
Sample our complete KBS Rust Prevention System risk-free. Here's everything you need to get started!
$17.95
Color:
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
  • The KBS System Sampler Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 12.5 square foot area. Don't get short changed, our kit includes 8 ounces of our RustSeal coating...not just 4 ounces. Twice the surface coverage!
  • RustSeal is a paint-like substance. RustSeal acts as a total rust inhibitor and preventive.
  • It's consistency is approximately that of paint and it has very good spreadability . KBS RustSeal chemically bonds to rusted steel to form a rock-hard, non-porous coating that won't crack chip, or peel. It works by isolating metal from moisture. Without moisture present, steel can't rust.
  • This non-porous, flexible coating is incredibly tough and extremely resistant to abrasion and impact. RustSeal is highly surface tolerant and capable of adhering to almost any prepared substrate
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Our System Sampler Kit seals 12.5 sq. ft. with two coats.
  • 8oz. - AquaKlean
  • 8oz. - RustBlast
  • 8oz. - can of KBS RustSeal (any color)
  • Nitrile Gloves
  • Two Brushes
  • Stir Stick
Sampler   7/1/2008
Customer service and products were both excellent!
Reviewed by: Jim from Quakertown.
KBS Sampler   7/1/2008
I have used POR15 before on other projects, but had heard that KBS was better so I decided to try it. The kit was just what I needed and reasonably priced. I am attempting to restore a set of 1955 Texas License plates to go on a 55 Chevy I am working on. It is my first attempt on plates, but KBS has sure made it easier. When I am finished, I will send you a picture. Thanks for a quality product at a reasonable price.
Reviewed by: Aaron Morrison from Burleson, TX.
Sampler Kit   7/1/2008
Worked great used the cleaner and etch and left light rust like film painted the 50" Torro deck twice left a hard coating the grass just washed off. I will coat my next deck the same way!
Reviewed by: Greg L from Oberlin Ohio.
Write a Review
KBS Frame Coater Kit
$55.00
More Info from KBS Coatings
$110.00
KBS All-In-One Chassis Kit
$85.95
