Home > Restoration Kits
Average Rating
Write a Review or See Reviews
Email this page to a friend
KBS System Sampler Kit
Sample our complete KBS Rust Prevention System risk-free. Here's everything you need to get started!
$17.95
Color:
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
  • The KBS System Sampler Kit contains everything you need to clean, prep, & apply two coats of RustSeal on up to a 12.5 square foot area. Don't get short changed, our kit includes 8 ounces of our RustSeal coating...not just 4 ounces. Twice the surface coverage!
  • RustSeal is a paint-like substance. RustSeal acts as a total rust inhibitor and preventive.
  • It's consistency is approximately that of paint and it has very good spreadability . KBS RustSeal chemically bonds to rusted steel to form a rock-hard, non-porous coating that won't crack chip, or peel. It works by isolating metal from moisture. Without moisture present, steel can't rust.
  • This non-porous, flexible coating is incredibly tough and extremely resistant to abrasion and impact. RustSeal is highly surface tolerant and capable of adhering to almost any prepared substrate
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Our System Sampler Kit seals 12.5 sq. ft. with two coats.
  • 8oz. - AquaKlean
  • 8oz. - RustBlast
  • 8oz. - can of KBS RustSeal (any color)
  • Nitrile Gloves
  • Two Brushes
  • Stir Stick
The kit did exactly what it is advertised to do!   9/2/2008
The kit did exactly what it is advertised to do. I would say that one needs to be a bit careful about hand painting though. The product goes on really well, but one is tempted to put a bit too much on and it sags. That is the applicator's fault not the product.
Reviewed by: KT from Howard SD.
Sampler   7/1/2008
Customer service and products were both excellent!
Reviewed by: Jim from Quakertown.
KBS Sampler   7/1/2008
I have used POR15 before on other projects, but had heard that KBS was better so I decided to try it. The kit was just what I needed and reasonably priced. I am attempting to restore a set of 1955 Texas License plates to go on a 55 Chevy I am working on. It is my first attempt on plates, but KBS has sure made it easier. When I am finished, I will send you a picture. Thanks for a quality product at a reasonable price.
Reviewed by: Aaron M. from Burleson, TX.
Sampler Kit   7/1/2008
Worked great used the cleaner and etch and left light rust like film painted the 50" Torro deck twice left a hard coating the grass just washed off. I will coat my next deck the same way!
Reviewed by: Greg L from Oberlin Ohio.
Works like a charm.   6/30/2008
I've used this two times now and I am quite pleased with the results.
Reviewed by: Lance from Cincinnati OH.
KBS System Sampler Kit   6/2/2008
It worked out great! I have a corvette and hate the rust that deposits around the rotors. A lot of people paint the rotors but I wanted them to look original. I used the clear and the rotors look new. It takes the heat and harsh debri that accumulates on the rotors. This stuff is tough and awesome!!!!!
Reviewed by: Matt from Quincy.
Worked well   6/1/2008
So far, the KBS system is holding up well on my ''93 Accord. It probably will allow me to drive the car for several more years. Unfortunately, I ran out, so the one tiny spot that I took a short cut on has a little rust. Also - if you are clumsy like me, make sure to mask the area. (Parts of my tires are rust-proof now too!).
Reviewed by: Carl P. from Rochester, NY.
sampler kit   5/30/2008
great kit for small job. works very good.will buy again. thanks for a great product tom L
Reviewed by: thomas l. from derry Pa..
System Sampler   5/26/2008
Saved me $1200.00 to replace the oil pan on my ''01 PSD. One sampler kit was enough to cover my pan with 4 coats of paint... It seems very solid and tough. I would definitely recommend this kit to anyone with rusty truck parts.
Reviewed by: MIke S. from Northwest Indiana.
sampler kit   4/27/2008
man go for it. just got done painting could not be more plz. saved me a lot of work.
Reviewed by: dave n from mcminnville or.
good stuff   4/2/2008
great product this is the second application that i have used this product on and both have turned out better than expected. will continue using. and keep telling my friends.
Reviewed by: barry m. from travis afb california.
Single mom''s LOVE KBS   2/4/2008
My boys have bikes that have truly taken a beating with the beach weather! I can''t afford to buy the boys new bikes, that would cost me a small fortune! So, I decided to try out this KBS system. The boys and I decided to just dive into it and see where it took us. Much to my delight, it was an incredible experience. This system was so easy to use, and the end results are beautiful! My boys actually love their bikes more now than they ever did! Keep up the great work KBS!!
Reviewed by: Kelli D from Irvine, Ca.
great product   2/2/2008
i like the product tank appears clean so far still restoring car
Reviewed by: hartley from florida.
Great sampler kit   11/1/2007
Super durable finish and easy prep directions.
Reviewed by: Caesar M from Jackson, MI.
Paint is awesome   10/25/2007
I loved the look of the paint when it was all done. I used glossy black on my smoker. The sampler kit was sufficient to do the entire smoker.
Reviewed by: LynnO from Jupiter, FL.
Appears to be a good value   7/7/2007
Kit was inexpensive, and contained all the materials to refinish the outside of a fuel tank.
Reviewed by: David R from Dallas, TX.
Sampler kit   7/5/2007
Great product. I had salt corrosion on my Ford Windstar and F250. Following the step by step instructions left me with not rust and a rock hard replacement.
Reviewed by: John S. from Houston, TX.
Highly Recommend!   5/22/2007
Bought a 98 F-150 with heavy road salt damage to lower interior of three doors. Took it down to bare metal with a die grinder/pad, and applied all three steps exactly as directed. I now have no more rust appearing, no paint peeling or chipping and it looks very professional. The Rust seal silver was almost a perfect match to the existing Ford silver. The sampler kit worked very well, as I didn`t need a large amount. I am very pleased with the results. This product is the best I`ve found for rusty metal. I`d highly recommend, and will buy again for other projects.
Reviewed by: Ron K. from Adell, WI.
KBS System Sampler   5/21/2007
I have worked at this dealer for 29 yrs,and have never used a product that worked as well as KBS products.
Reviewed by: Pat J from Atlanta, GA.
Good stuff!   12/6/2006
Early indications are that it`s as good as POR and costs much less. That being said, I won`t say it`s better until it proves to stand up as well over time. Check back with me in about 10 years. Seriously, if it equals POR`s success it`s a bargain. I`ll continue to buy it unless it proves to be less reliable over the long haul.
Reviewed by: MET from Winter Haven, FL.
Great Stuff   11/6/2006
Awesome Product, Absolutely awesome. Will be buying more!
Reviewed by: David S. from Pickens, WV.
I recomended this to all my auto refurb buddies   10/18/2006
Excellent system... that is and ENTIRE system with everything you need (down to the gloves.
Reviewed by: Scot H from Abelene, TX.
KBS SAMPLER   10/18/2006
GREAT SERVICE! SEEMS TO BE AS GOOD AS POR 15
Reviewed by: KEN S. from Chicago, IL.
sampler kit   9/25/2006
looks good on my weather vane shaft. It`ll be exposed to the elements, A tough test at best.
Reviewed by: John R from Winter Haven, FL.
KBS System sampler Clear   9/25/2006
Got this as part of the 2-for-1 share with a frend, so was a super value. Fast shipping, easy to apply. seems to have less fumes that POR-15.
Reviewed by: Tom W from Abilene, TX.
Sampler Kit   9/24/2006
Great products...amazing customer service!
Reviewed by: John J. from Morristown, NJ.
Kit kicks POR-15 butt   8/19/2006
I was a loyal POR15 user for nearly 10 years, till I got this kit yesterday (great service too!). I used it today and WOW!! Saw your ad on "Trucks TV"...looked good. Need any dealers?
Reviewed by: Dave V. from Columbus, OH.
Just try it!!!   7/6/2006
perfect kit for my job. All products worked very well & instructions were easy. The paint looks great too! Cheap, fast shipping.
Reviewed by: Brad F. from Casper, WY.
system sampler   6/14/2006
It`s a great kit at a great price if you have a small job or just want to sample all the products. Appreciated the paint stick that was included!!
Reviewed by: joe c. from Huron, SD.
 Add Review KBS System Sampler Kit
Review Title:
Review:
Rating:
= Required
