Home > Rust Sealer
Average Rating
Write a Review or See Reviews
Email this page to a friend
A terrific solution that fits your budget! Here’s a DIY restoration kit that will save you $$$ versus the cost of replacement. Restore your floor pan, trunk, or pick up truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included.
$110.00
RustSeal Color:
NuMetal Color:
Gloss Black
Gloss Black
Satin Black
Satin Black
Off White
Off White
Clear
Clear
Grey
Grey
Silver
Silver
Oxide Red
Oxide Red
Guardian Green
Guard Green
  • You can maintain the integrity of the structure with no ugly welded seams. Our easy step-by-step instructions make it simple to restore floor pans, trunk pans, pickup truck beds, etc.
  • You'll be amazed how complete it is... More of what you need ... Everything you need is at your fingertips.
  • KBS Coatings’ 3-STEP SYSTEM of RustSeal (a rust preventive coating), KBS AquaKlean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today.
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Gal. - AquaKlean
  • Gal. - RustBlast
  • Qt. - RustSeal (any color)
  • 1 lb. - NuMetal Epoxy Putty
  • Sq. yd. - BackBone Reinforcing Mesh
  • 8 oz. - #1 Thinner
  • KBS Paint Spout
  • Nitrile Gloves
  • Mask
  • Two Brushes
  • Stir Stick
Trunk and floorpan repair kit   5/2/2008
This is the best product I have tried. I used three different products like this before and KBS seems to be the best.
Reviewed by: jerry McC. from Dayton Tn.
KBS-Trunk-Floorpan-Repair-Kit   4/2/2008
I was a little skeptical as I've never used this product or anything like it before but I needed to fix rusted through floorpans on my restoration project. I was pleasantly surprised with how hard the product is after drying and how well it worked to fix the rusted through parts. I would definitely use again and would recommend to anyone thinking about using it-especially if you don''t have access to a welder or patch panels for your project. I can''t wait to prime and paint !
Reviewed by: Jim P. from Colleyville, Texas.
This stuff is great!!!   2/13/2007
This stuff works really well. All of it was very easy to work with and to apply. And, you can`t beat the price! I wouldn`t hesitate to recommend this to anyone.
Reviewed by: Marcus L from Lakeland, FL.
Write a Review
KBS Frame Coater Kit
$55.00
More Info from KBS Coatings
$118.00
KBS All-In-One Chassis Kit
$85.95
