High Temperature Paint
Home > Rust Sealer Bookmark and Share
Average Rating KBS Coatings
A terrific solution that fits your budget! Here’s a DIY restoration kit that will save you $$$ versus the cost of replacement. Restore your floor pan, trunk, or pick up truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included.
$110.00
RustSeal Color:
NuMetal Color:
*Kit includes Paint Spout, Black Lightning Gloves, Mask, Brushes and Stir Stick.
Gloss
Black
Satin
Black
Off-White
Clear
Grey
Silver
Oxide
Red
Guardian
Green
Galvanized
Steel
*Click HERE for the unique characteristics of Galvanized Steel and to order.
RustSeal - Stop Rust - Like POR-15
  • You can maintain the integrity of the structure with no ugly welded seams. Our easy step-by-step instructions make it simple to restore floor pans, trunk pans, pickup truck beds, etc.
  • You'll be amazed how complete it is... More of what you need ... Everything you need is at your fingertips.
  • KBS Coatings’ 3-STEP SYSTEM of RustSeal (a rust preventive coating), KBS AquaKlean (an industrial strength water-based cleaner / degreaser) and KBS RustBlast (a powerful rust remover / metal etch) is the most effective rust and corrosion prevention system available today.
  • Single component formula
  • High solids content
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
  • Gal. - AquaKlean
  • Gal. - RustBlast
  • Qt. - RustSeal (any color)
  • 1 lb. - NuMetal Epoxy Putty
  • Sq. yd. - BackBone Reinforcing Mesh
  • 8 oz. - #1 Thinner
  • KBS Paint Spout
  • Nitrile Gloves
  • Mask
  • Two Brushes
  • Stir Stick
KBS Coatings
KBS Instructional DVD
Ratings - KBS Coatings Worked Great
I used this kit for the rusted trunk pan in my 59 Ford Galaxie. It worked great and I feel confident putting my new floor mat over the finish. One recommendation I have is if you have larger holes to patch, you can use some of the nu-metal putty, and put it on a piece of the fiberglass mesh and use that as a patch, then paint over it. It dries solid and really fills any holes.
Reviewed by: Robert from Denver, CO. on 10/1/2008
KBS Coatings
Ratings - KBS Coatings Corvette Floor Pans
I used KBS floorpan kit to make my rusted out 76 Stingray floor pans look like new. The self leveling quality of KBS resulted in a smooth glossy black finish. Easy to use. I have recommended it to others doing similar restorations.
Reviewed by: R Smith from California. on 8/29/2008
KBS Coatings
Ratings - KBS Coatings kbs trunk floor pan kit.
i used your kit to do the floor of my 1987 ford ranger truck . kit was easy to use , instructions were very good , results ! a nice looking floor in about 20 hours . about 3-4 hours of total work . i have used por15 and find your product and instructions BETTER.
Reviewed by: walt p from erie, il. on 7/31/2008
KBS Coatings
Ratings - KBS Coatings even for problem jobs
I needed to seal the inside of my honda gas tank I ran across kbs coating system and what a deal I was especially concerned about getting the whole inside of the tank but add the rust blast seal the tank and roll it around ... the fact that it was a proper viscosity for spraying was another plus good product....
Reviewed by: John Burdge from sutherlin, or 97479. on 7/24/2008
KBS Coatings
Ratings - KBS Coatings Trunk and floorpan repair kit
This is the best product I have tried. I used three different products like this before and KBS seems to be the best.
Reviewed by: jerry McC. from Dayton Tn. on 5/2/2008
KBS Coatings
See All Reviews
Paint For Rust
$118.00
Paint For Rust
KBS Frame Coater Kit
$55.00
Paint For Rust
KBS All-In-One Chassis Kit
$85.95
