KBS Coatings Ordering & Info  |   Support Forum |  FAQ's & Support Tickets |  Reseller Finder |  Free Catalog
Motorcycle Resto Kits
Work Gloves
KBS Gear
KBS Work Gear
Directions Pages
The KBS 3 Step
Rust Prevention System
The KBS 3 Step
Tank Sealing System
Concrete Sealer
DiammondFinish
Clear
DF Top Coat
Fusion Self-Etching
Primer
XTC Zinc Primer
Tech Support Forum
FAQ's
1-877-548-9323
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Home > Rust Prevention
Motorcycle Frame Coater Kit
This complete Motorcycle Frame Paint Kit takes our popular System Sampler Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes 8oz of BlackTop topcoat for a permanent final finish on your bike frame which withstands dulling and fading caused by prolonged sunlight exposure.
Price:
$45.95
  Only $9.95 Shipping per order.
RustSeal Color:
BlackTop Color:
Usually Ships Same Business Day.+More Info
Questions about this item? Be the first to ask here.Got a Question about the item? Ask Here!
Need a Larger Kit? Our All-In-One Chassis Coater Kit contains a enough to do a 50 sq.ft. area. +Go HERE for the All-In-One Chassis Coater Kit.
Gloss
Black
Satin
Black
Off-White
Grey
Silver
Oxide
Red
Guardian
Green
Safety
Blue
Cat
Yellow
Galvanized
Steel
Motorcycle Frame Kit Overview
This complete kit takes our popular System Sampler Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes 8oz of BlackTop topcoat for a permanent final finish on your bike which withstands dulling and fading caused by prolonged sunlight exposure.
  • KBS Klean - An Industrial Strength Cleaner & Degreaser.
  • RustBlast - A Rust Remover & Zinc Phosphate Metal Prep.
  • RustSeal - A Non Porous Waterproof, Rust Preventive Sealer. Available in your choice of 10 colors.
  • BlackTop - A Superior Topcoat With Unbeatable UV Protection & Flexibility. Available in Gloss Black or OEM Satin Black.
  • #1 Thinner – Use to Thin Spray Applications and for Clean Up.
  • Brushes, Gloves, Stir Stick & Instructions - The Intangibles Needed For Every Project.
  • Will cover 12.5 sq. ft. - 2 Coats of RustSeal, 1 Coat of BlackTop.
Motorcycle Frame Kit Features
  • Single component formula
  • High solids content
  • Widest array of (10) non-porous color formulas
  • Mold and mildew resistant
  • Superior flow and leveling
  • Moderate UV stability
  • VOC compliant
  • Lead-Free
Motorcycle Frame Kit Contents
  • KBS Klean - 8oz.
  • RustBlast - 8oz.
  • RustSeal (any color) - 8oz.
  • BlackTop (either color) - 8oz.
  • #1 Thinner - 8oz.
  • Black Nitrile Gloves
  • Two Brushes & Stir Sticks
  • Complete & Detailed Instructions
Enough to cover 12.5 sq.ft! (2 Coats of RustSeal, 1 Coat of BlackTop)
Customer Reviews
Paint For Rust
Frame Coater Kit
$61.95
Paint For Rust
Large Frame Coater Kit
$99.95
Paint For Rust
4 Quart Special - Convenience Gallon
$144.95
Recently Viewed Items
Subtotal $0
Sign Up Today!
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
We Want
Part Numbers
KBS Coatings - Barbados
Barbados
KBS Coatings - Denmark
Denmark
KBS Coatings - Germany
Germany
KBS Coatings - Russia
Russia
