Home > Prep Products
KBS AquaKlean
KBS AquaKlean
AquaKlean is a concentrated, water-based, biodegradable formula that is an excellent alternative to flammable solvents & hazardous chemicals for preparing your paint job with a clean surface. This powerful cleaner will deeply penetrate and remove stubborn soil from most surfaces without leaving harmful residues or emitting noxious fumes.
More Info from KBS Coatings
KBS RustBlast
KBS RustBlast
KBS RustBlast is a powerful rust remover and zinc phosphate pre-primer & metal etch. RustBlast effectively dissolves rust, corrosion, metal oxides, and tarnishing from most metal surfaces, while providing extended protection against flash-rusting thanks to KBS' unique Oxygen-Block technology.
