| Motor Coater Engine Painting Kit |
$49.95
| As every painting professional knows, the keys to any long lasting paint job are good surface prep and the use of quality materials. Our complete KBS Motor Coater Kit was developed to guarantee just that! Your engine will be a show stopper at this DIY price...too bad it's kept under the hood! |
| Large Cycle Tank Sealer PLUS Kit |
$44.95
| Our "PLUS" Kit contains everything found in our LARGE CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank. |
$40.95
| Our "PLUS" Kit contains everything found in our regular CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank. |
| KBS System Sampler Kit |
$17.95
| Sample our complete KBS Rust Prevention System risk-free. Here's everything you need to get started! |
| KBS Frame Coater Kit |
$55.00
| Our quart size 3-Step System kit includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coat paint coverage. DIY protection at a tremendous value! Detailed instructions included. |
| 4 Quart Special :: Convenience Gallon |
$118.00
| Buy four quarts of RustSeal to maximize your savings and avoid waste. Best buy for multiple larger size projects. Each RustSeal quart provides 2 coats of coverage for an approx. 50 sq. ft. area. Mix or match colors. |
| KBS 4PAK :: Convenience Quart |
$45.95
| A full quart of RustSeal in four user-friendly 8oz. cans. Each can provides 2 coats of coverage for an approx. 12 sq. ft. area. Open only what you need. Best value for small or multiple projects. Mix or match colors. |
| KBS Trunk & Floorpan Repair Kit |
$110.00
| A terrific solution that fits your budget! Here’s a DIY restoration kit that will save you $$$ versus the cost of replacement. Restore your floor pan, trunk, or pick up truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included. |
| KBS All-In-One Chassis Kit |
$85.95
| This complete kit takes our popular Frame Coater Kit to the next level. In addition to the complete KBS 3-Step System, this kit includes a pint of BlackTop topcoat for a permanent final finish which withstands dulling and fading caused by prolonged sunlight exposure. |
| KBS Cycle Tank Sealer Kit |
$35.00
| A great 3-Step cost savings kit designed for the repair of motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 5 gallons. Detailed instructions included. Satisfaction guaranteed! |
| KBS Large Cycle Tank Sealer Kit |
$39.00
| A great 3-Step cost savings kit designed for the repair of motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed! |
| Auto Fuel Tank Sealer Kit |
$59.00
| A money-saving 3-Step repair kit which includes enough products to clean, prep & permanently seal up to a 25 gallon tank. Detailed instructions included. Satisfaction guaranteed! |
