Home > Rust Sealer
KBS RustSeal - Stop Rust
RustSeal in ColorKBS RustSeal is a superior one part, ready-to-use, high-solid content, rust preventive coating, that is actually strengthened by exposure to moisture. It is impervious to road salts and most every chemical. RustSeal flows out to a beautiful, rock-hard, tough coating that is tough to chip or scratch. These exceptional properties make RustSeal specifically formulated to prevent corrosion and stop rust. RustSeal completely seals metal surfaces, blocking all the pores and preventing penetration of moisture, oxygen, and water vapor. Available in gloss black, satin (OEM) black, silver, grey, oxide red, guardian green, clear & galvanized steel. Try some today...you'll be amazed!
  • APPLY DIRECTLY OVER RUST!
  • SEALS & ENCAPSULATES RUST AND POROUS SURFACES
  • APPLY BY BRUSH, ROLLER, OR SPRAY.
  • SUPER STRONG AND FLEXIBLE - HAMMER TOUGH!
  • HIGHLY RESISTANT TO MOST CHEMICALS
  • MODERATE UV STABILITY, UNLIKE OTHERS WHICH CAN CHALK WITHIN WEEKS
  • COMPATIBLE WITH ALL PAINT SYSTEMS
      RustSeal Galvanized Steel
Introducing our newest RustSeal color ... GALVANIZED STEEL! We've replicated the look of an industrial galvanized matte finish with this new color formula of RustSeal, while enhancing the UV stability. RustSeal Galvanized SteelThe Galvanized Steel color can be used in all the same applications as our original RustSeal colors, but is particularly suited for industrial applications where a rapid build of a rust protective coating is needed to smooth and level rough surfaces, without gassing or sagging. The RustSeal Galvanize Steel Advantage is that it is 3 products in 1 ... a permanent rust preventive coating, a high build primer, and a UV enhanced topcoat! Use Galvanized steel in conjunction with AquaKlean & RustBlast for the most complete rust prevention system available today! Get More Info.
KBS RustSeal - Galvanized Steel
Introducing our newest RustSeal color…GALVANIZED STEEL! We've replicated the look of an industrial galvanized matte finish with this new color formula of RustSeal, while enhancing the UV stability.
More Info from KBS Coatings
KBS System Sampler Kit
$17.95
Sample our complete KBS Rust Prevention System risk-free. Here's everything you need to get started!
KBS Frame Coater Kit
$55.00
Our quart size 3-Step System kit includes enough products to Klean, Blast & Seal a full-size car or truck frame, or any 50 sq. ft. area with 2 coat paint coverage. DIY protection at a tremendous value! Detailed instructions included.
$118.00
KBS 4PAK :: Convenience Quart
$45.95
$110.00
A terrific solution that fits your budget! Here’s a DIY restoration kit that will save you $$$ versus the cost of replacement. Restore your floor pan, trunk, or pick up truck bed back to new and never deal with rust again! Easy-to-follow detailed instructions included.
KBS All-In-One Chassis Kit
$85.95
