Stop Rust Paints
Motorcycle Resto Kits
Nitrile Gloves
Latex Gloves
Work Gloves
KBS Gear
Directions Pages
DF Clear Coat
DF Top Coat
Fusion Self-Etching
Primer
Xtreme Temperature
Coating
Search Our Knowledgebase
877-548-9323
Home > Stop Rust Paints
KBS RustSeal - Galvanized Steel
Introducing our newest RustSeal color…GALVANIZED STEEL! We've replicated the look of an industrial galvanized matte finish with this new color formula of RustSeal, while enhancing the UV stability.
8oz. - $15.95  |  Pint - $24.95  |  Quart - $37.95
Gallon - $119.95  |  5 Gallon - $529.95
$0.00
Size:
Color:
RustSeal Galvanized Steel - Stop Rust
RustSeal Overview
Introducing our newest RustSeal color ... GALVANIZED STEEL!
We’ve replicated the look of an industrial galvanized matte finish with this new color formula of RustSeal, while enhancing the UV stability. The Galvanized Steel color can be used in all the same applications as our original RustSeal colors, but is particularly suited for industrial applications where a rapid build of a rust protective coating is needed to smooth and level rough surfaces, without gassing or sagging.
The RustSeal Galvanize Steel Advantage is that it is 3 products in 1 ... a permanent rust preventive coating, a high build primer, and a UV enhanced topcoat! Use Galvanized steel in conjunction with AquaKlean & RustBlast for the most complete rust prevention system available today!
It’s technology that’s unbeatable! Satisfaction guaranteed!
RustSeal Features
  • Ready-to-use single component formula
  • High solids content (75%)
  • Superb coverage with high build, filling & leveling properties
  • Superior toughness & durability
  • Uniquely flexible - expands & contracts with temp changes
  • Resistant to fuels & most chemicals
  • Withstands temps up to 600°F (312°C)
  • Fast moisture cure rate for easier re-coat - rock hard finish in 24 hrs.
  • Self-leveling - brush, roll or spray
  • Galvanized-look finish
  • Can be top coated
  • Enhanced UV stability
  • All of the Other Features of RustSeal
RustSeal Applications
Unique Galvanized Steel Applications: steel roofs • metal fencing & posts • brake calipers • steam pipes & pipeline repairs • factory parts & equipment • to seal fuel or water tanks • general steel fabrication • welded metals • steel construction beams
Other Uses: hand rails • support beams • lawn equipment • garage floors • pipe work • appliances • lead-based paint encapsulation
RustSeal Coverage Rate
  • 8 oz. of RustSeal will cover 12.5 sq. ft. with two coats.
  • A Pint of RustSeal will cover 25 sq. ft. with two coats.
  • A Quart of RustSeal will cover 50 sq. ft. with two coats.
  • A Gallon of RustSeal will cover 200 sq. ft. with two coats.
  • A 5 Gallon Pail of RustSeal will cover 1000 sq. ft. with two coats.
RustSeal How-To's
RustSeal Galvanized - Before and After
KBS Coatings
KBS Instructional DVD
Customer Reviews
Paint For Rust
Paint For Rust
KBS System Sampler Kit
$18.95
Paint For Rust
$114.95
Recently Viewed Items
Pre-Val Spray Gun
Pre-Val Spray Gun
KBS RustBlast
KBS RustBlast
Facebook
Twitter
KBS Coatings on Google Plus
Google Plus
KBS Coatings on YouTube
YouTube
KBS News / KBS Blog
KBS Coatings in Magazines
KBS Coatings - Germany
Germany
KBS Coatings - Denmark
Denmark
UK
