High Temperature Paint
Home > Supplies
KBS Instructional DVD - Vol. 1
$0.95
Now you can get our helpful videos in pristine DVD quality, sent right with your order for only $0.95. This DVD includes eight episodes, showcasing our three most popular KBS products in everyday applications.
More Info from KBS Coatings
We'd like to introduce you to the newest version of non-latex gloves on the market. While everyone has seen nitrile gloves before, we’re sure that you’ve never seen or felt any gloves like these!
White Lightning Gloves
Made of super strong Extra Thick Powder Free Reduced Latex Protein, White Lightning Gloves protects your hands and provides better barrier protection from oils, solvents, chemicals and bio-hazards than vinyl or other thinner latex gloves.
KBS BackBone Reinforcing Mesh
$7.00
A thin pliable reinforcing fiberglass mesh that lays flat to form an invisible patch made of unbeatable strength & holding power. Easy to use. No bunching, bulging or stiff loose hairs to ruin your finish. Use in conjunction with RustSeal or NuMetal to repair holes and bridge gaps in metal, wood or fiberglass.
KBS Paint Spout
KBS Paint Spout
Flexible Paint Spouts eliminate messy drips and keep grooves clean for resealing cans. One size fits gallon, quart, and pint cans. Order enough for all your paint cans.
Pre-Val Spray Gun
Pre-Val Spray Gun
KBS Paint Brushes
KBS Paint Brushes
Quality brushes at a disposable price. Made with natural bristles for superior paint pick up and a smooth uniform finish.
KBS Dry Air Spray Gun Filter
Downstream moisture will ruin your spray job. Stop failure with our direct in-line filter at the gun.
