Home > Tank Sealers
Gas Tank Sealers
Gas Tank Sealer KBS Tank Sealer
Used by professionals worldwide, Gold Standard Fuel Tank Sealer is a superior, one part, ready-to-use fuel tank sealer that is specifically formulated to stop rust and corrosion. When used in combination with AquaKlean and RustBlast, it will form a super-tough, fuel and alcohol impervious coating, while simultaneously sealing small pinholes and weld seams. Gold Standard may be used on steel, aluminum, and fiberglass tanks. Applications include fuel tanks, diesel tanks, oil tanks, utility tanks and non-potable water tanks. It's been rated as the industry‘s NEW Gold Standard in gas tank sealers.
Gold Standard Fuel Tank Sealer will stop rust and form a tough, fuel impervious coating while sealing small pinholes and weld seams. Your fuel will never touch the inside walls of your tank again.
More Info from KBS Coatings
KBS Cycle Tank Sealer Kit
$35.00
Cycle Tank Sealer PLUS Kit
$40.95
Our "PLUS" Kit contains everything found in our regular CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
$39.00
A great 3-Step cost savings kit designed for the repair of motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
$44.95
Our "PLUS" Kit contains everything found in our LARGE CYCLE TANK SEALER KIT, "PLUS" a quart of KBS STRIP to quickly remove any old failing sealers previously used to seal your tank.
Auto Fuel Tank Sealer Kit
$59.00
KBS Tank Sealer Instructional Videos
