Home > Tank Sealers
Gas Tank Sealers
Gas Tank Sealer
Used by professionals worldwide, Gold Standard Fuel Tank Sealer is a superior, one part, ready-to-use fuel tank sealer that is specifically formulated to stop rust and corrosion. When used in combination with AquaKlean and RustBlast, it will form a super-tough, fuel and alcohol impervious coating, while simultaneously sealing small pinholes and weld seams. Gold Standard may be used on steel, aluminum, and fiberglass tanks. It's been rated as the industry‘s NEW Gold Standard in gas tank sealers.
Gold Standard Fuel Tank Sealer will stop rust and form a tough, fuel impervious coating while sealing small pinholes and weld seams. Your fuel will never touch the inside walls of your tank again.
More Info from KBS Coatings
KBS Cycle Tank Sealer Kit
$35.00
$39.00
A great 3-Step cost savings kit designed for the repair of motorcycles, generators, lawn mowers, tractors, snowmobiles, or other small tanks up to 12 gallons. Detailed instructions included. Satisfaction guaranteed!
Auto Fuel Tank Sealer Kit
$59.00
